Question about D-Link DI 514 Wireless Router (DI-514)
I play xbox live but i need to increase my mtu settings, how do i do this?
    Sergeant:
    Champion:
  • 310 Answers
Under WAN configuration in the web interface of the router, you should have the option to change the MTU size. To get there, type http://192.168.0.1 in your browser. In the page that comes up , type the username / password as admin / and hit enter ( blank password )
Hope this helps
Thanks Ranjit ranjit@supportminds.com
Posted on Jun 16, 2009
3 Suggested Answers
  • 31 Answers
SOURCE: MTU
maybe the manual of that router can help:
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
  • 35 Answers
SOURCE: I need to increase my MTU settings on my router for Xbox LIVE.
You can do that by configuring your router. Look for the default ip address of yoour router, it can be found in your router's manual. After you found it, run internet explorer and type in your ip address (ex. 192.168.10.1). There you o just enter your username and password and your on your way to the configuration process. Go to internet setup and under DHCP Internet Connection Type you can change MTU there. Just give it a try...
Posted on Jun 21, 2009
I am 14 and was playing xbox live, it shut me offline and when i diagnosed the proble it said my mtu setting need to be at least 1364, how can i fix that?
MTU is the maximum size (in bytes) a protocol is able to send. Not super familiar with xbox but I would check under your network settings. Although I doublt the xbox will allow you to set this. So the next step would be to check your router settings. You will need the following
  • A PC or laptop
  • Ethernet cable
You will need a computer plugged in via ethernet into your router.
  • Open a browser and enter the gateway address in the address bar
  • You can obtain your gateway address by going to a command prompt and typing "ipconfig"
  • Login to your router (if you've never setup the router with a login it will probably be a generic login such as admin/, admin/admin, / or /admin
  • Look for your MTU setting, this is generally under the advanced settings
  • Set it to 1500 if it is not already.
Please comment with how the xbox is connected to your network as well Comment back if you need more assistance
Another cause of xbox live booting you is if someone logs into your xbox live account else where as xbox live only allows for one login at any give time.
Aug 12, 2011 | Computers & Internet
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
I can not connect to xbox live
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Video Game Consoles & Games
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
X-BOX
Jan 23, 2011 | Computers & Internet
The dsl is red and when it turn green i still can connect to xbox live, but when i try to connect my xbox says i need a higher mtu is that possible to change from a laptop
X-BOX
Jan 21, 2011 | 2wire (1000-400108-001) Router
I need to know how to open my nat type for xbox live
X-BOX
Jan 10, 2011 | ASUS (SL1000) Router
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
How do I change my MTU settings?
Today would be a bad time to test for a connection issue with XBox Live. It is down today for maintenance, if it worked before today, I would just wait until tomorrow and try again.
http://www.product-reviews.net/2009/06/16/xbox-live-down-on-june-16-maintenance-also-for-zune/
Jun 16, 2009 | Belkin (F5D5231-4) Router
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
Sep 30, 2008 | Video Game Consoles & Games
D-Link DI 514 Wireless Router (DI-514) Logo
156 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
