Question about Amana DigiSmart PTC123B35AM Thru-Wall/Window Air Conditioner
A/c doesn't cool -- froze up, then thawed, now it doesn't cool
I found an 800 # for Amana in the HD Warehouse catalogue -- 877-376-0214 -- and called to talk to a tech. He walked me through a diagnostic test, which was a matter of pushing some buttons on the very simple t'stat and fan pad (only a few buttons to choose from according to his instructions, which led to readouts where the temperature ususally is). He took note of what the readouts were and told me exactly what the problen was -- "the red wire that goes from the coil to the transistor board, because your numbers tell me that it's 188 degrees...and it's not, I hope" -- and then he took my address and mailed me one.
We'll see -- it should be here in a couple of days.
Posted on Jun 17, 2009
Ive been putting water n my car due to small radiator leak water froze n overflow bottle n also froze n all the holes car won't start due to the ice wat can I do to melt ice n holes
Get the car towed to a garage that has heat and allow the water to thaw out. Then, drain the cooling system since there is too much water and not enough antifreeze in it. Now is a good time to repair/replace the leaking radiator. Refill and bleed the cooling system with a 50/50 mix of water and antifreeze. If you don't repair the radiator, keep some 50/50 mix available for topping off to prevent freeze-ups in future.
Nov 23, 2015 | Cars & Trucks
After an extreme cold spell,98 malibu will turn over but will not start
What is your coolant to water ratio? If you have too much water your system may have froze. If so let it thaw and hope it didn't crack anything in your cooling system.
Dec 25, 2013 | 1998 Chevrolet Malibu
Froze up now won't cool
turn system off or leave the fan only on and thaw system out, when it is dry, check filter, if not the problem more than likely it was turned down to low or the freon charge is low and should be check by technician.
Dec 09, 2012 | LG LS-L1210CL Mini Split Air Conditioner
HOTPOINT Refrigerator HSS25GFPE WW - Freezer has some frost and cools but do not freeze. The refrigerator is not cooling at all. Can not ifind the mannual or ifnormation of this particular model in any...
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Hotpoint Refrigerators
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
Frig or freezer is not cooling
Tap on the freezer knob and see if refrig comes on . If so , replace the freezer thermostat ( piece with the knob ) .
Jun 04, 2010 | Frigidaire FRS23KF5C Side by Side...
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
Refrigerator not cooling below 55 degrees. Freezer works fine. Coils under refrigerator are clean and compressor is running.
Check the defrost timer, it may be out, if the coils in you freezer are all froze over with ice it may stop your fan from circulating the cool air to the frig side, this is cause by the defrost time not working. It will need to be replaced. You will need the model number and to thaw the coils with a heater or to unplug the frig while it thaws. If this is your problem call First
Source and provide with model number and ask for a defrost heater. Replace per instructions.
Jul 05, 2009 | Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Amana DigiSmart PTC123B35AM Thru-Wall/Window Air Conditioner Logo
133 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
