Question about OKIFAX 2600 Fax
Our minolta fax 2600 is showing us we have a polygonal error
How do we clear it and what does it mean
  • 37 Answers
Not 100%, but I would say this referring to the laser unit.
Switch off/on...if no joy, it's probably an engineer job.
Posted on Jun 19, 2009
How do i clear error c4154
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 17, 2015 | Konica Minolta Minolta Bizhub C253 Copier
Why am i getting the error message * memory rx 2P Recording Paper Jam? I can t find a jam anywhere?
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Jun 27, 2014 | MinoltaFax 2600 Printer
POLYGONAL ERROR / WHAT DOES THIS MEANS AND HOW I WILL REST IT... THANKS
Polygon error. There is a LASER inside the machine which hits a 5 sided minor spinning at about 35000 rpm. That minor is spun my the polygon motor. More then likely you have a bad print head. That is what the entire assy. LASER/motor/Minor/Sensors are called. Power off/then on if it comes back have a technician looks at it.
Feb 26, 2013 | Minolta MF2800 Plain Paper Laser Fax
On my fax Minoltafax 2600, I have the following error message "error polygon" and the fax does not work anymore, what has the engine polygonal can you help me please Thank you in advance
Polygon is the motor that is located inside the FAX print hear which is where the LASER is located. Have a technician (Konica Minolta) have him check the connection between the print head and its control board. If not need a new print head or worse the control board for the whole machine.. The polygon motor is what makes the LASER beam move across the drum to place the image on the drum, it travel around 35.000 RPM, you mite heard it as very high pitch as gets up to speed. So the LASER and the Motor are inside the PRINT HEAD.
Jun 07, 2011 | MinoltaFax 2600 Printer
Polygonal error on a minolta fax 2600
First check the connection between main control board and print head. The Print Head house the LASER and a motor called the polygon motor which is use to spread the laser bean across the drum. IT move at about 35,000 rpm some time you can hear it when machine turn s on, so check the connection if good get a new print head worse case the control board is bad
try below web site they mite have parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 06, 2011 | MinoltaFax 2600 Printer
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Minolta Fax 3600
Yeah, pretty much s(****). That message means the polygon mirror in the laser unit is not spinning up.
If you want to try to fix it, it's a square black box under the top covers. You can take it apart and oil the mirror shaft.
Sep 07, 2008 | Office Equipment & Supplies
Activity Report Codes
NG means "no good". it means your fax didn't go through correctly or wasn't received correctly. ie wrong number of pages etc.
Apr 29, 2008 | MinoltaFax 2600 Printer
OKIFAX 2600 Fax Logo
163 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
