Question about Kyocera FS-2000D Laser Printer
Error code 7410
I have a similar problem, but the error code is 7410:0104645. The printer had had paper jam before the error message showed up on the screen. I already cleared the paper jam, replaced the toner, and reset the printer a couple times. But the message is still there. Can anyone help me with this problem? I really appreciate your help
Thanks,
Lauren
    President:
  • 3,085 Answers
Open the left side door, push in on the drum unit which is above the waste toner bottle until it clicks.
Turn printer off then on.
Posted on Jun 16, 2009
Paper jam HP officejet 7410
If it shows where the jam is go there. Open the cover and remove paper.
Aug 24, 2013 | HP OfficeJet 7410 All-In-One InkJet...
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam
hi...
1)After years of heavy use the rubber rollers which transport the paper through the printer can get a shine to them and tend to loose their grip. This causes misfeeds and blockages.
Using a damp cloth and something like Jif (slightly abrasive kitchen/bathroom cleaner) rub the rollers whilst rotating them by hand. With a clean damp cloth remove any cleaner and you should see the rubber has lost it's sheen.
Some rollers can be hard to get at but a little patience pays off. I've reclaimed dozens of printers due to be scrapped in this way.
You can also try turning the printer upside down and softly tapping it. You could be surprised at what drops out. My best to date was pieces of an illegal plant substance and a rare Chinese coin. (Yes it was returned to the owner :-)
or
2)The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. (images 1 to 2)
7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. (Image 3)
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
thank you
Jul 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
C6180 clear carriage jam
Change ur categer and clean ur inside the printer,and delete old documents.
Jul 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error message DC1560
This code shows that paper feed is jam in left side.just check any paper is jammed in this side.or sensor liver is pressed in paper path.by MIAN JEE
Nov 17, 2008 | Kyocera KM-1505 Copier
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Error code: 7410
Hy, i have had the same problem.
turn the power switch to off,
open the left cover,
push on the label
close the left cover
turn the power switch to on
Jan 30, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
499 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
