Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Reboot w/ new power supply
I was having the problem with the blinking amber light (addressed in a previous post here) and got a new power supply. I decided to upgrade to 470w from the factory installed 350w. My system now seems to boot 80% of the way, then begins to reboot, occasionally with nothing on the monitor. It cycles through the reboot until I manually power down. Any ideas?
  • Pohjie Nov 01, 2007
    Thanks for the fast reply. I should add that I reinstalled the old power supply and the system is running normally. I'd still like to put in the newer, nicer unit.
  • 1,006 Answers
I recomended you first to clear cmos settings and check the ram!
Check the hdd if it is OK?
Let me know if u get help???
Posted on Nov 01, 2007
I cannot detect any problem with the computer other than the power lights continues to blink amber and white. Help.
If the power light is blinking Amber or Yellow, your power supply is no good. You can purchase a new power supply either online at places like or you can take your whole computer into a store like bestbuy and ask them to show you power supplies that will work with your computer.
If you are unsure on how to replace your power supply, I would suggest taking it to someone that will install it properly.
There are also a lot of videos out there like this one:
That show you how to do it yourself. Just make sure all the power connections are connected or you might have devices that dont' work properly.
Have a great day.
Jan 23, 2010 | Dell Dimension 8400 power supply ** FREE...
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Only amber light is on when green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
Blinking Green power light
Unplug the power cable and press and hold the power button for several seconds to discharge the system. Then allow several minutes before reconnecting the power cable. If the problem still persists, it may be a failed power supply.
Nov 20, 2008 | Computers & Internet
Dell 2400 PC- blinking amber light.
Hi Sherri,
The symptom that you are facing generally refers to bad power supply. The same can be resolved by replacing the same. You can call dell sales to procure a new power supply. However to troubleshoot and make sure if power supply has gone bad , use the link below
Nov 03, 2008 | Dell Dimension 2400 PC Desktop
The power light blinks all the time
Does your machine turn on? Is the blinking light red or amber? If you have it plugged into a UPS or surge protector try directly into wall socket.
Please give a little more description, also what was the last thing you did before this happened?
Aug 12, 2008 | Computers & Internet
Blinking power light
check your power supply. A flashing amber power button usually means its gone bad
Jul 15, 2008 | Computers & Internet
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
51 people viewed this question
Alun Cox
