Question about Mitsubishi WD-52525 52" Rear Projection HDTV
52" dlp 52" mitsubishi dlp wd52631 suddenly will not turn on at all. Reset button gives blinking light. When the light stops I'm supposed to turn it on. Doesn't do anything.
  • 3 Answers
YOU NEED TO RESET THE TV. USE A PAPER CLIP TO HOLD DOWN THE BUTTON, AFTER THE LIGHT FLASHES FOR ABOUT ONE MINUTE YOU SHOULD BE ABLE TO TURN ON THE TV.
Posted on Jun 21, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Green blinking light
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Gren Light on 52 Inch DLP
It most likely burned out the Lamp. DLP TV's need time to cool the Lamp after power is turned off.The fan will run for a few minutes after a normal power off condition from the front control button or the remote.When you lost power, the lamp was still hot and was unable to cool down.You can replace the Lamp yourself.Go to www.dlplamps.com
Jul 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
DLP Lamp Replacement
yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Apr 01, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
TV won't come on
Im not at home right now so I can not get the exact part number but you need the powersupply for this set. There are numerous bad capacitors on this board and you might have a blown main on here. Replacing this will repair your set back to working condition.
Josh
Feb 21, 2008 | Mitsubishi WD-52631 52" Projection HDTV
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
