Question about Kenmore 24032\24036 Top Load Washer
The cold water will barely run out to fill the machine.
I'm sure it is stopped up, but I can't find my manual and I can't remember how to how to clean it out. We have a lot of sediment in our water and I'm sure that is what's causing the "blockage", so to speak. Can someone show me a diagram of how I need to go in and clean it out, please?
Here is the information on the Kenmore Top Loading Washer:
Model No. 23812100
SN: CM4589545
Series 80
Type 111
10 AMPS
120 VLTS
60 HZ
    President:
  • 1,185 Answers
Pull the machine forward
Turn off the water supply
Turn on the machine as if you are doing a wash, if it is hot and cold fill turn on the hot wash so that the hot valve is used
Turn off the machine
Use a cloth to grip the plastic or metal wing nuts which secure the cold and hot pipes to the back of the machine
Loosen them off and remove them one at a time making sure that you do not lose any sealing washers
Remove the filters and clean them
Put the hoses back on and make sure they are tight
Turn the water back on and start a wash using both 40 and 90 degree programs as you did in the first place
If the water runs in as normal make sure that there are no leaks and put the machine back into position
Use the machine and at the end of the session check that the connectors are still tight
Posted on Jun 16, 2009
My washer machine stopped working and now have no cold water in machine
first thing to check is for a clogged filter screen at the cold water connection on the machine. the screen will often fill up with crud and create a blockage. Clean and reinstall or replace the screen for both hoses.
remember to shut off the water before you disconnect the hose, and while you have it off, try running some water into a bucket to rinse other grit out of the line before reconnectind and to confirm that water is getting to the machine.
Jul 07, 2013 | Home
When trying to wash with hot water only machine fill slows and adds cold water then adds hot this continues until load level is reached and you end up with barely warm water is there any way to fix this...
see the causes and use the common sense. God bless you
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Sep 22, 2012 | Roper Washing Machines
The washing machine won't fill with water at all. we have cleaned the pump valve and we have checked the water lines. are there any other things that could be causing this problem?
You will want to check and make sure the door handle/lock is switching on. the front load unit will not fill with water with the door open. Check that the latch is engaging.
Oct 05, 2010 | GE WSXH208A Front Load Washer
When washer fills up it only fill with hot water. the cold water do not even run in machine. Then when it goes to the rinse cycle water is not filling up in machine. It comes out just alittle bit. is there...
The cold water solenoid valve or the controller is defective. It is more likely that the valve is defective. Of course, check to make sure that the cold water feed is turned on.
Jul 31, 2009 | Whirlpool Washing Machines
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
295 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
