Question about Gateway GT5028 PC Desktop
GT5028 I bought one thinking it would be an easy fix, well not so far. took out everything and tried to get a beep error, but nothing. So it isn't memory, video card, or monitor. It is either CPU or motherboard. I am looking for a cheap CPU to but in it to check which one it is. But if someone else determines the problem please tell everyone because this seems common.
  • Mark Schurman Jun 16, 2009
    Yes I tried a new PSU first. I hoped this was the easy fix part, but was wrong.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
You may have a failed motherboard or power supply unit (PSU) then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting anything after you removed all the components. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
And remember a bad PSU does not mean no power, just not enough to run the computer. If you have tried another PSU is the PSU that you replaced the same or greater output watts? I had one in my shop and determined it to be mobo.
Posted on Jun 16, 2009
New gateway dx4840 lga1156 core i3 and I get a steady beep sound. not a beep code. even with everything disconnected
I had that happen before when my RAM went bad. I think I shorted it out by not having it clicked in all the way, I don't remember. Maybe try swapping some RAM out one at a time and see what happens. Make sure the RAM is also in its right spots (like if you have 4 slots there is one in slot 1 and not in slot 3) I hope this helps.
Feb 04, 2014 | Foxconn 45CMX socket LGA775 motherboard...
Dell inspiron 560 problems
chek your video card it my be going out
Apr 30, 2013 | Dell Inspiron 560 PC Desktop
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Del Latitude PP01L won't boot up
there may be a problem of ur RAM, it might not be fit properly in the "RAM SLOT" or it might be a hardware fault of ur RAM..
Aug 29, 2009 | Dell Latitude D600 Notebook
Turns on, no bios no screen, just beep.
Now the question is, when the computer first starts up and you hear the beep, that is where it will tell you what your problem is depending on the beep you get.
One Long and one Short Beep = Motherboard issue
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue
One Long and Three Short Beeps = Video (EGA) Display Circuitry
Three Long Beeps = Keyboard error
One Beep, Blank or Incorrect Display = Video Display Circuitry
If it is the last one, then try doing the following.
1. Disconnect external devices = Unplug everything from the back of the computer and then restart it. If it starts up, then it is one of the peripherals that is plugged in. You will then need to turn off the computer and gradually plug each one in and turn the PC back on to see if the peripheral is the problem. If that isn't the problem, the proceed to #2.
2. Cable check = With the computer shut down, make sure all the cables within the PC are attached properly. Once you finish doing that, turn on the PC and that isn't the cause, continue on...
3. Disconnect all expansion cards = Sometimes another expansion card can become loose and cause various amounts of issues. Remove each expansion card (clean them if necessary of dust) and replace them. Turn on your PC. If it doesn't start move to the next step.
4. Disconnect all drives = disconnect the data cables from the CD-ROM, hard drive, and floppy drive from the motherboard (make sure to mark them so you remember where they plugged into). This will either remedy the situation or you will see an error when you reconnect each device one at a time to determine which device/cable is causing the issue.
5. Remove the RAM = Loose or bad RAM can cause PC's to not boot or boot incorrectly. Remove each stick and replace them one by one alone in each memory slot. If the PC boots up in each slot, then your golden, but if a slot is defective, then your motherboard is damaged in that slot. You can still use the other slots as long as you use the defective one. If a stick of RAM doesn't allow your computer to boot up, its quite possible that stick of RAM is defective and will need to be replaced. But make sure you try out all the other options before throwing away a stick merely because the PC doesn't boot. A faulty stick can be the problem, but if the problem lies elsewhere, you may be throwing away a good stick of memory thinking it may be bad.
6. Disconnect and reconnect the CPU = Most CPU's are easy to remove, but if you aren't familiar with it. Read your manual on how to remove the CPU. Once you remove it and re-seat the CPU, reboot your PC.
7. If after you have tried all the previous steps and your PC still doesn't boot, then it is most likely that your motherboard, CPU, RAM, or power supply is defective and must be replaced. If you are unfamiliar with fixing the problem (or have never built your own PC) you can opt to have someone repair it or you can start with the cheapest option of purchasing a single stick of new memory and see if the memory was indeed the original problem. If the PC still does not boot with new memory, then it is most likely your motherboard, CPU, or power supply that is dire straights.
Aug 28, 2009 | Gateway GT5028 PC Desktop
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
The LG refrigerator ER FF fix
I had this same problem, with the thing freezing up, and this is how I solved it -- I took everything out of the fridge, I defrosted it for a few WEEKS (yes, weeks), cleaned the thing thoroughly, replaced the water filter, and fired it up again. So far, it's been two months, the thing is quiet as a grave, and running like a champ.
I think if you let ice form around the condenser fan, it will not go away easily. I tried the hair dryer trick, the "unplug it for a while" trick, but nothing worked. After a week or so I'd hear that grinding sound (which I think was the condenser fan and a huge chunk of ice doing their thing).
This refrigerator doesn't like to be opened a lot, and it doesn't like a door being left open, even a tiny bit, at all. The right door of the refrig can stay slightly open without the annoying beep happening, and the bottom freezer can also be slightly ajar and the beep won't go off. It's a trick to get everyone in the family to pay attention to this and make sure that the doors are all closed TIGHTLY, particularly the freezer door.
I called up the (not terribly helpful) LG people and they denied a systemic problem with the frig, and they also denied that cutting insulation was a good idea.
I am not sure what the truth is, but so far, so good with the lengthy defrost. Of course, if you don't have a spare frig, or you're not prepared to live out of a cooler for many days (I do think you need several days to get that massive block of ice melted) to try this fix, you may not be interested in it.
Jun 28, 2008 | LG LRFD25850 French Door Refrigerator
D Drive / E Drive
try to cange cable if not buy new unit 20 bucks pop in easy they fail often thx nick
Feb 04, 2008 | Maxtor Hard Drive
Gateway GT5028 PC Desktop Logo
184 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
