Leaking fluid drips seem to be back near catalitic converter
SOURCE: 1996 toyota tercel
there is no repair manual published for the 1996 tercel, not from chilton, not from haynes.
the 1994 tercel and the 1996 corolla are both covered in haynes manuals, that's the closest we can get. both have some of the same systems, gotta pick and choose.
there is an expensive professional repair manual, published by toyota, i think, that's what mechanics buy for shops. it costs hundreds, and is not easy to buy.
SOURCE: need to find specks on cylingder head for 1996 toyota tercel
The cylinder head bolt torque is a 2 step process.
First: Torque all of the bolts to 45 Nm (450 Kgf-cm or 33 ft lbs.)
Replace any head bolt that will not torque to the above specs.
Second: after all ten bolts are torqued to the above specs, the head bolts are then "Torqued to Distance"...
Starting at the center bolts, retorque all ten bolts an additional 90 degrees.
Hope this helps, the graciousness of a FixYa rating would be greatly appreciated.
SOURCE: My radiator (1996 Ford Explorer) is leaking at the
You can have it repaired at a radiator shop, or replaced with a new one. Are you sure it's the radiator that's leaking, sometimes it's the water pump or a hose that drips down onto the radiator. It can be difficult to locate due to air circulation of the fan and driving which spreads the leaking fluid around. I assume u top off the coolant often, since u say there are no issues w/ it overheating or running hot. If this is the case, the leak will eventually get worse, and adding coolant constantly gets expensive. Good luck, let me know what u decide to do, or if u have any other questions. Curt
SOURCE: head gasket on the 1996 4 cyl toyota camry
go to the library and borrow a manual its not a very hard job but you will need a manual.
SOURCE: Nissan Altima running hot
When the car is completely cool,check the electric fan(s) for smooth rotation.
Clean/check/change the thermo sensor,contact and wire.
Excavate air pocket in coolant system / check for head gasket leak
This test will kill two birds with one stone.
MAKE SURE THE COOLANT SYSTEM and ENGINE IS COLD!
RAN THIS TEST IN A WELL VENTILATED AREA ONLY!
You will spill some coolant during this air pocket purge test.......BE
KIND TO THE ENVIRONMENT and ANIMAL please clean up after the test!
Put the front end on a pair of ramp or park your car on a VERY STEEP HILL (radiator facing top of the hill) .
Top of the coolant reserve tank
Let it ran for 10-15 minutes.
Monitor for air pockets escaping from coolant reserve tank.
Small amount of bubbles is OK at 1-5 minute mark
After the thermostat open up (after 195 F warm up) at
5-12 minute mark or after high idle you should see less bubbles.
If you do not see any in rush of bubbles then your thermostat may be
partially stuck or rusted badly inside the thermostat hosing.
Give the thermostat host few gentle taps.
If you see larger bubbles surfacing after 15 minutes then should do a
hydrocarbon (HC) dye test to test for potential head gasket leak.
Let engine cold down and top off coolant reserve tank.
Start monitor for coolant lost
A coolant flush is require every 2 years or 24,000 miles.
I recommend the thermostat that has a relief pop-let to reduce the change of burst radiator and coolant hoses.
Make sure you get a new thermostat gasket,black RTV and fresh coolant for the job.
Please post more information by clicking the comment link on the top right corner.
DON'T FORGET to RATE ME if my tip is helpful to you!
Testimonial: "good stuff!! thanks."
