Question about HP Photosmart 8250 InkJet Printer
Card read error message appears
This is a new 4GB HP SD card. Will not download any images. I also updated all available upgrades.
  • 749 Answers
You need to FORMAT the card to use it.
Posted on Jun 16, 2009
Want to install 8gb
b> W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Determine the type of SD card you have. If it is 2GB or less, then it is a standard SD card. If it is 4GB or greater, then it is a high capacity or SDHC card. (There are some 4GB standard SD cards but most are SDHC). An SDHC reader is required to read the high capacity cards since the memory allocation formatting is different. If your data is on an SDHC card, it may be intact but you'll need the SDHC device to read it. Some devices, such as readers and cameras, may have software downloads available to upgrade the device to read the SDHC cards. Go to the device manufacturer's website to determine whether such an upgrade is available. Insert your SD card into the card reader. If no drive letter is assigned to it, then the computer isn't reading it. In some cases, the reader may be assigned a drive letter but when you click on it you get the message "Please insert disk into drive E:" indicating that it isn't reading the card. Sometimes a particular device may not read an SD card while other devices will. If you don't have another device, ask a friend to try reading your card. You may find that your computer accesses the card, but won't read the files on it. Try several different files on the card. If some of them read and some don't, then one or more files may be corrupt. There are numerous file recovery programs available; some of them are free. If certain vital parts of the file are corrupted it won't be recoverable. Sometimes scanning the SD card will fix things. It usually won't correct a bad file but it may be worth a try. To do this, locate the card in "My Computer" or Windows Explorer" and right-click on it. From the pop-up menu, click on "Properties." A new window showing a pie chart displays the used and available space on the disk. Select the "Tools" tab, then click on the "Error Checking" button. Click the check box for fixing file system errors and click the "Start" button. The process should only take a few seconds. In some cases, none of the files can be read. Sometimes the directory will list the file names but the files can't be accessed. In other cases, the file names are garbage characters or they may not show up at all. Right-click on the drive letter and select "Properties." The pie chart will show the used space on the card. If it shows all or almost all free space, then either the files have been deleted or the directory has been erased. In this case, a file recovery or undelete program may help (but don't count on it). If you card reads okay but you can't save a file, the card may be write protected. On the edge of the card is a small slide switch usually labeled "Lock." If this switch is slid away from the connector end of the card, then it is "locked" or write protected. To save or modify files on the card, the switch must be in the unlocked position or toward the connector end of the card. If you still can't read or write to the card, your files are probably lost. There are some disk diagnostic tools available, but some of them won't work on memory cards. If you have resigned yourself to the loss of your files, you may still use the card by reformatting it. To do so, right-click on the drive letter and select the format. This will erase everything on the card so be sure you have copied everything you can to another drive. When the card is reformatted the directory structure is recreated so you should now have full access to the card. If the card still won't work, it's time to discard it.
b>
Oct 22, 2012 | Kingston 4GB Secure Digital High Capacity...
Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures....
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
Aug 11, 2017 | Office Equipment & Supplies
I accidentally used a damaged SD card on my Kodak P712, so it flashed that "error" message. but after that every SD card i used, whether my own or new, it always flash that "error"...
The problem is that your camera will only read SD cards, not SDHC cards. After you damaged the SD card that you've been using for years, you bought a replacement, not noticing that it was SDHC. The new cards don't work, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 19, 2011 | Kodak EasyShare P712 Digital Camera
It doesn't read 8gb sd cards on internal sd drive
There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
Nov 22, 2009 | Dell Latitude D430 Notebook
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
HP Photosmart 8250 InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
