Refresh and follow this steps-
Adjust the driver setting to print using only the black ink
Note The images below are used as an example. Actual screens may vary depending on the printer model and OS being used.
Select the Main tab.
Select Plain Paper as the Media Type.
Note If any other paper type is selected, color ink will be used to create black.
Plain paper selected as media type
Select the box for Grayscale Printing.
Grayscale printing selected from Main tab
Click OK to save the changes.''
Regards,
Rachel Gomez
Check da tonners
SOURCE: Printing black only documents with Canon PIXMA iP4000 printer.
Has anyone messed with the color schemes? they may cause that to happen too.
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
SOURCE: IP4000 Color Printing Problem
If you have a monochrome option, I would use that.
I'm guessing that your old black and white photo's (which I'm thinking you scanned in may have a sepia tinge which the printer is emphasizing, and if you only want black/white prints, no need to print with colour.
SOURCE: I have a Canon Pixma
Be sure you removed cartridge protection tape before installing cartridges.
SOURCE: my canon ip4000 was working perfectly until
It could be a few different things but letys try the easiest first. Go into control pane/jprinters/ and do a deep nozzel cleaning. leave the printer idle for about a hour or two before trying to print again. You may have to repleat this procedure. If this does not fix your problem it could mean that you need to update a driver for your printer or that you have changed your colour settings in a graphic program such as adobe. Failing all else you may just need brand new cartridges. I have a canon i860 and found a very inexpensive site online to order the cartridges for a few dollars each. even if you don't need the cartridges right now check out the site and stock up.
http://www.piloshop.ca/index.php?main_page=advanced_search_result&search_in_description=1&keyword=canon+i+series+cartridges
