Question about JVC TH-C50 System
No Speaker Cables
I have a JVC TH-C50 receiver and manual.  I do not have the speakers or the cables.  The manual shows the 8 pin speaker jack on the left rear of the unit.  Does anyone know where I can get the cables?  I would like to use my own speakers.  Any details on hooking up the speaker system would be greatly appreciated.
Duke in GA
  • augie123 Nov 14, 2007
    I have the exact problem. Someone on ebay mis-represented what came with the unit. now I am stuck in the same boat as you. Any help would be greatly appreciated.
  • flyinbrian Apr 01, 2008
    I just purchased the TH-C50 and am pleased but the 8 pin mini din is used as a proprietary cable in this config. and makes it impossible to use this reciever/DVD or sub any other place. I would like to use these speakers with the computer in the same room so I don't have 2 sets of surround spkrs in the room. I need to know JVC's pinning on that mini din. With the pinout diagram for that connector I could have a "A"- "B" speaker switch or a mono 5 plug surround breakout cable made.
This is a s-video cable, same as used for video signals, i bought a gold plated one and all works awesome
Posted on Dec 18, 2007
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
Acs 45.1 We have the components, but no cables to go from the computer to the base. What should the two connector cables look like? One end looks like pins, the other like a connector jack.
-->The pin cable goes from the control speaker to the base. Red connector in this picture.
--> The 1/8" mono goes from the other speaker to the control speaker. White mark in the control speaker.
--> the SW has 2 inputs (m-m 1/8" stereo cables) 1 comes from the audio out of your sound card,
   the other is the subw input, you can connect this if your sound card has that output.
Good luck
Rate my response please.
Jul 12, 2011 | Altec Lansing ACS 45.1 Computer Speakers
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Mar 02, 2011 | JVC TH-C50 System
I have a jvc seteup but reciever is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
Jan 12, 2011 | JVC TH-M505 System
I have a JVC Th-c50 Home Theater It holds 5 cd's, or dvd's my grandson decided that it should hold 8.. I removed them all, now it shows no disc when loading?? It it expensive to have this repaired or what...
check all internal cables again, may be you turned over the flat ribbon cable to the loader. Check if all the cds is loading ok, that there is no mechanical blocking underway.
Sep 03, 2010 | JVC TH-C50 System
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
JVC TH-C50 System Logo
133 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
