Question about Star Logic 17" LCD Monitor
Error message on the 19" monitor
"out of range". and won't work.  The manual states may not be compatable with pc.  It is a HP A6123W pc.  I have never had this problem
  • 38 Answers
Re: Error message on the 19" monitor
Its not a compatibility problem in that sense. Its the screen size./refresh rate boot into safe mode if that works is those settings. set then to 1024x768 and 60-75 hertz
Posted on Oct 31, 2007
0 characters
3 Points
Out of range 90.0khz/60hz
does the dock havae a power button? if so, place laptop on dock while cosed and turn on through the dock.
Feb 06, 2013 | LG W1943SS 19" Monitor
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computer Monitors
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Sounds like your PC has changed resolution to one not compatible with your monitor. Try to boot in safe mode to change the resolution to more basic. Then reboot.
Monitor Mike
Apr 24, 2010 | Optiquest Computer Monitors
When cconnectng my ati radeon 7200 VGA output I get the "out of range" message. What is causing this?
It means your monitor is being fed a video signal that it can not process. In other words, you have settings that are not compatible with your monitor. Check your resolution, refresh rate and settings of the like.
Oct 18, 2009 | Princeton Digital VL1916 19" LCD Monitor
Out of range message indicates that you are running at a resolution or refresh rate that is not compatible.Go to your display settings and change to different settings.
Sep 25, 2009 | Princeton Digital VL1916 19" LCD Monitor
Out of range
You can try removing signal cable from pc.If it still says "Out of range" most probably main logic card or interface board as it is known in the lcd monitor could be defective.If on the other hand removing the signal cable gives message No signal ,cable not connected,try connecting monitor to another working known pc.If it still doesn't work the interface board in the monitor is defective.
Feb 26, 2008 | ViewSonic VX924 19" LCD Monitor
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Star Logic 17" LCD Monitor Logo
46 people viewed this question
Top Star Logic Computer Monitors Experts
Fernando Torres
Fernando Torres
Are you a Star Logic Computer Monitor Expert? Answer questions, earn points and help others
