Can't receivee a fax. Machine stays in selftest mode
We have a HP Office 6210 Fax Machine that won't go out of selftest mode. Any recommendations? We have unplugged it, had the telephone line checked, and also took it to another office to no avail.
Bob Buckland, Phone #:850-882-5954, E-mail: robert.buckland@eglin.af.mil
  • 1 more comment
  • bucklanr Jun 16, 2009
    The ink cartridges would not move to the left for replacement. Also, when you unplug the fax machine and plug it back in you hear nothing and it starts showing Selftest and the indicator marker showing it is selftesting stops when it gets to the right side of the display screen.
    Cartidge carriage slid easily to the right for changing cartridge, but would not move back to left automatically, had to manually push it back to position, and the selftest display did not change.
    None of it helped. Cartridge did not move after replugging the machine in, and plugging in the machine while holding down the # and 3 key selftest came back on, cartridge did not move, Selftest and the indicator marker showing it is selftesting stops when it gets to the right side of the display screen. I guess it would be cheaper to trash it and buy a new one rather than ship it for repair.
  • 1,959 Answers
If it's out of ink, it would remain in sef test mode until it's able to print a report. Make sure the unit is plugged in and check the ink cartridge(s). This may have been the problem that initiated running the self test all along. Post back with any other questions or comments.
Greg
Posted on Jun 16, 2009
  • 1 more comment
  • Greg Margossian
    Greg Margossian Jun 16, 2009
    If it's stuck in self test, it's normal not to hear anything. Try moving the cartridge carriage to the left manually and see if it:
    • Stays in position to allow a cartridge change
    • Moves back to it's prior position
    • Gives a different error and/or the self test error changes
    the cartridges ride along a chain and should slide freely. If they are stuck then you've isolated the problem.
  • Greg Margossian
    There are 2 other options:
    1. Check to see if there is a paper jam; this would also prevent a self test report from printing
    2. With the cartridge carriage in the middle, unplug the machine; when you plug it back in, the carriage should return to it's normal position on its own
    3. Try to reset; Unplug the machine, Press and hold the "#" and the "3" simultaneiously while plugging the machine back in, release when display resets
    If none of these options fix your problem, then I'm afraid a service call will be needed. Best of luck.
    Greg
  • Greg Margossian
    You might want to remove the rear door and poke around. It wouldn't take much to trip a paper jam error which also would prevent the self test from completing. Wish I could do more for you Bob. Please reconsider the negative rating you gave my solution. I did work on the issue and although I may not have solved the problem, I'm sure you found some of the information helpful in some way. All the best.
    Greg
HP 6210 fax not picking up - rings around 6-7 rings, then tone, then the line drops.
I HAD THE SAME ISSUE. I NEEDED A DEDICATED LINE FOR THE FAX MACHINE.. ALSO IN THE OWNERS MANUEL ON PAGE 77 -79 IT GOES INTO DETAIL AT THE VARIOUS SETTINGS TO HAVE THE FAX ANSWER
Jul 13, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a rather generic question- should I expect a home/office all in one machine to last more than a couple of years. I do a moderate amount of printing. And should I expect to be able to print...
in simple - NO - No machine is built to last anymore. My experience is genrally between 18 and 24 months is about the life of this tyoe of machine and even if it is still going at that point the inks will become so expensive it is wioth changing anyway
Jul 12, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a HP 6210, it is not hooked up to computer. I only want to use it to receive and send faxes but its not working
The following link will take you to your user manual on the HP.com web site. Go to fax setup (chapter 10) then "Choose the right fax setup for your home or office". It shows several scenarios to setup your fax. Hopefully you can find what you need. GOOD LUCK!
h10032.www1.hp.com/ctg/Manual/c00238458.pdf
Oct 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Phone Line Requirements for HP 6210 All-In-One Fax
If you do that I believe what will happen is that the Fax machine will answer your phone,unless you can set it to not answer until after so many rings, and you answer it first,beofere that number of rings. You will have to installor program  the software for the fax part of your printer .
Feb 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP J 6480 Fax
1, plug in fax line in line jack on all-in-one unit
2, hit the fax key
3, key in fax number whitch you want to fax
4, hit start
Dec 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
Hp 6210 Fax Problem
no this issue may occur if you line is noisy.You can also try to change the FAX SPEED to slow and the same time turn-off ERROR COrrection MODE.
- you can locate this options on the ADVANCE FAX SET_UP
Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
103 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
