Question about Poulan Pro 22" Self Propelled High Wheel Mower
Lawn mower started and then died about 20 seconds later, I restarted it and had the same result. Now it starts and runs for about 20 seconds but gets hardly any RPMs
Is there a adjustment on the push mower for "lean"
It makes a sound of humming Up then Down
Posted on Jun 22, 2009
  • 26 Answers
Clean carburator change spark plug sounds like you left gas in tank over winter and it gummed up
Posted on Jun 16, 2009
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
5hp Briggs mower. Over heats
What do you mean by 'overheats'?
If it runs for a period of time then dies but will restart after it cools back off the ignition module is suspect.
Run it with the airbox cover and air filter removed. when it fails immediatly spray a shot of carb cleaner in the carb and try to restart. If it wont start its the module if it does start and you can keep it running on a prime then its a fuel issue.
Nov 09, 2012 | Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
Starts runs then dies. will start again in 20 min,
Simple thing is to check the filters..air & fuel. Good chances is if it is not in the carburetor then its the coil. www.nnyparts.com
May 27, 2010 | Mtd Gold 42" Zero-Turn Mower -
Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Mar 04, 2010 | Garden
20 HP Craftsman lawn tractor starts easily, but only runs
This is classic dirty gas filter ... I dont say that is all it could be ... but is it classic dirty filter. You might have something in the tank that is blocking gas getting out of the tank.
check it out ...
Oct 20, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
Starts on first pull. Runs about 30 seconds and dies.
Found the air filters on both mowers were so saturated with oil there was not enough air getting to the carburetor. Cleaned the filters first with dishwasher detergent and hot water, dried them, then soaked them in aclcohol to remove more oil. Dried filters, installed on mowers, and both mowers now run fine.
Jan 17, 2009 | Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
495 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
