Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
SimpleTech 500GB External Drive stops or freezes etc
I use my SimpleTech to store mp3s and I listen to them from there. (I:)
Winamp is installed on my hard drive. (C:) It used to work fine, but now music skips then freezes and the drive (I:) can no longer be accessed.
I also get the Delayed Write failed error. I tried reducing the cache size with cacheset. This happens only when using Winamp.
Sometimes when I turn Simpletech on, it simply will not show up. I have to use the usb port to get it to come back. And most of the time I can't eject it. Generic Volume can't be stopped. Even after using Unlocker.
This thing drives me crazy. I feel like it's only a matter of time before I lose everything on it.
IB4G2008
  • 3587 Answers
SOURCE: PC cant detect my Simpletech 500gb hard drive
well..you can 'see' it on the my computer, right? welll, then perhaps you'll check the usb cable, no?
Posted on Apr 03, 2008
msuhelk
  • 106 Answers
SOURCE: PC cant detect my Simpletech 500gb hard drive (pininfarina design)
SOMETIME WHEN THE RAM IS LESS THE ADDITIONAL DRIVES ARE NOT READ WHEREAS THEY ARE SHOWN AS AVAILABLE, BUT WHEN YOU CLICK ON THAT , THE PC HANGS....SO FIRST CHECK HOW MUCH RAM YOU ARE USING, IF IT IS LESS THEN UPGRADE IT BY MINIMUM 1 GB TO PERFORM THIS TASK
JulesPCaut
  • 702 Answers
SOURCE: Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
Posted on May 03, 2009
platsak
  • 18 Answers
SOURCE: 500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Posted on Jun 17, 2009
  • 4 Answers
SOURCE: Six month old Simpletech 500 GB ext. drive not recognized
I had the exact same problem. Solved by removing Simpletech drive from the 'flashy-box'. Unplugged drive from internals and threw the 'Pinnaferrina' case away and installed it on my motherboards extra sata plugin site (if it has one). If you open your computer case it should be labled on the Motherboeard as such. Mine has four. On the first attempt when I started the computer i Had no OS system showing on first boot-up. Shut off computer and power and shifted SATA (RED Cable) to another Sata plug on Motherboard and it booted right up and I had the drive back. You will need a longer Sata cable than the attached to the Simpletech drive and a power cable that matches the one on the Simletech . Forget looking for the drivers on the net and the Simpletech web site was no use.
Posted on Nov 02, 2009
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Lost simpletech 500gb adapter
You will need a 12V, 2A tip positive power supply. You can easily find one at Radio Shack or Best Buy, etc.
Sep 28, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Freezing
Maybe some bad sector in there. You should do a disk scan to check that.
Jun 24, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I have a simpletech pininfarina 500 external hard-drive and cant find driver software online to install it.computer also doesnt recognise it
I have found a driver page of simpletech:
http://www.simpletech.com/support/support_downloads.php
I believe that driver for your model is not available in the above link.
The drive would not be recognized when it is not compatible with your notebook hard disk.
I suggest you to contact simpletech for getting the drivers as they will have the hard disk drivers.
Jun 19, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Hello.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech Signature 500gb "is not accessible"
Right click on MY COMPUTER and select MANAGE.
Go to DEVICE MANAGER and expand the DISK DRIVES category on the right side window.
You should see the Simpletech drive listed under there. Delete the Simpletech drive and click on OK. Restart the computer.
Windows should re-detect the simpletech and re-install the built in drivers automatically.
Jun 17, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
192 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
