Question about HP Audio Players & Recorders
I have a HP laptop and my speakers only work when headphones are plugged in! any idea how to fix that?
    President:
  • 1,185 Answers
Right click on the little icon of a speaker on the left hand side of the lower taskbar or go into Control Panel and select Sounds and Audio Devices
When it opens click on the Advanced tab at the bottom and select the speaker you want to use Save the setting and exit
Posted on Jun 16, 2009
My laptop plays sound out of both my speakers and headphones.
It sounds like that port is set to mono, go to properties and check that.
Jan 10, 2015 | HP Pavilion Computers & Internet
Audio jack seems to have short
There is probably a broken solder where the audio jack connects to the mainboard. If you are in warranty, then contact HP and they will fix it free of charge. If not, then pick up a usb sound card. They are cheap ($20), plug into a usb port, and have a speaker and headphone jack. This will fix it.
Regards,
Joe
Apr 07, 2012 | HP Compaq 6510B 14.1" Laptop
Hi .i have hp compaq 610 laptop.my in build speakers not working.how can solve the problem.please help me.
The inbuilt speakers on my laptop do not work. I believe the headphone input socket to be the problem because when i stick my headphones in it only works if i squeeze the laptop near the socket. The input has been quite heavily used so i'm quite certain its broken somehow. Anyway, my layman theorising has led me to the conlcusion that my laptop thinks that headphones are plugged in when they're not and so disables the speaker so maybe if i could disable the headphone input the speakers might work. I'm sorry if this sounds confusing but my computer knowledge is really, really limited. Any help would be massively appreciated. thanks
Jan 02, 2011 | HP Compaq Computer Speakers
Laptop Internal Speakers
When you plug headphones in, that opens the circuit on the speakers, so that you can avoid annoying people. If someone tried to put in a plug that was too large, or bumped it, the contacts could have gotten bent. If you can get at the inside of the headphone jack, you could probably bend it back to being in contact again.
Oct 03, 2009 | HP Pavilion dv6226us Notebook
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Jun 08, 2009 | HP EliteBook 6930p Notebook PC
My speakers and headphone jack
you need to go to http://www.hp.com and choose your computer from the laptop list clcik on help and support, next put your computer modle into the search box or have it auto detect your system, then download the drivers you need and this will fix your problem, do not remove drivers to make more space..
Jun 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP laptop speakers not working
hi,
whenever you put in the head phones the speaker will stop working and when you take the headphones out they will start working again this is their normal behaviour.
Further Queries are welcome
Feb 21, 2009 | Acer Aspire 3680 Laptop
Headphone jack not working
i just had it solved once for my frend. . wat to do is uninstall everything realted to yur sound hardware .. and get the latest updates ... from ..their site ... and install it .. it will work .. before .. doin this just try ....
1 conect the headphone
2 open the mixer .. in that there will selection of device. .. from that select headphone if it is available. ..
thnx
Nov 04, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone Speaker Jack Needs Replacement
That honestly sounds more like a headphone wire problem than anything else. If you have another headset, headphones or speaker system that you can hook up, I would test it on those to try to rule that out as a problem.
If that isnt it, I can try to find the disassembly instructions for your laptop. (Unless your warranty is still good, in which case I would tell you to send it in and get it fixed professionally.)
May 16, 2008 | HP Pavilion ze4125 Notebook
41 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
