Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Low pressure blinking on Laars LX heater - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
  • jeff ross May 11, 2010
    check filter pressure gauge ,higher than normal can cause lower flow to heater. pressure switch in heater will not open to allow call for heat
    Top Expert:
  • Jandy Master
  • 8,861 Answers
Check pressure switch
Posted on Apr 29, 2016
3 Suggested Answers
  • 990 Answers
SOURCE: my laars lx pool heater is blinking LOW PRESSURE.
The heater needs good water flow or it will overheat. You probally have a full basket in your pump or your filter is dirty.
Posted on Jan 21, 2010
  • 760 Answers
SOURCE: My Jandy Laars LX 400,000 BTU heater flashes "low pressure"
Once you try to ignite three times in succession, and the heater doesn't sense the presence of flame, the heater goes into "lockout" mode and must be reset to fire. This can be done by pressing and releasing the mode button so that the heater is turned off then returned to the desired mode. So if you were going to "jumper" the pressure switch, (connecting two wires together) make sure you do the reset also. Make sure you don't operate like this, if your pump quit, you could have a melt down. Also If you have anything connected to the fireman switch, it is in series with the pressure switch,and woud display the same thing. There is a terminal with two white wires, if there is a jumper there, then nothing conected, but if there is something connected, make sure it is closed. Also be sure your code was for Water pressure and not air pressure switch. You can download manuals at: www.jandy.com
Posted on Jul 27, 2010
My laars lx 250,000btu just displayed a "low
Check your baskets for plugs or your filter may be dirty. The impeller may be clogged in your pump if your pump basket is set wrong or if it has any cracks in it. These will all drop the pressure to the heater.
Aug 13, 2011 | Jandy Laars Lx 250,000 Btu Heater
Message 'LOW PRESSURE' on my Jandy LX pool heater. How do I check the fuse?
Check your flow and pressure from the pump first.... May need backwash, skimmer/strainer cleaning.. If you get an error message, chances are the fuses are ok.
Jun 16, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My laars lx cycles on and off then shuts down. Error code AGR
How fast does it cycle? If it is quick like less than a minute the unit is not recognizing the flame. Could be bad flame sensor, bad ignition, low gas pressure, ground wire loose.
Mar 06, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My laars lx pool heater is blinking LOW PRESSURE. How do I fix?
Jan 20, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pressure switch lite blinks
inside the heater , but hold downd what is the pressure for the filter. that is the anwser low impeller plug or worse line plug high after the filter something is not let the water back to the pool
Sep 05, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
465 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
