Question about Fisher and Paykel GWL11 Top Load Washer
Washing machine not draining and finishing cycle
I have a Fisher & Paykel washing machine which will not drain; therefore, it never finishes the cycle.
I've unplugged it several times (as recommended in the manual), but so far, that hasn't helped.
I've attempted to put it through the last cycles several times, but it always stops without draining.  Lights blink on and off and there is a constant beep.
I've checked both hot & cold hoses - they are on.
I cannot tell if any water is siphoning out of the washer because the hose is taped into the drain hole.
I hope you can help.
Thank you.
Patsy Knight
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Posted on Nov 01, 2007
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Look at my issue under "eco smart won't drain, smells hot". On normal cycle, I couldn't get all the water to spin out and my problems just got worse until I had leaking on floor and motor burned up.
I had a sock that made it all the way into the drainage area above the motor. I couldn't see the sock when I looked between the plastic tub and the interior tub.
To remove sock, tip washer back, remove white plastic housing/black motor unit, and you can see into tub area where i found the sock. More explicit instructions on how to remove this unit are on my post "eco smart won't drain, smalls hot". Good luck! Ann
Posted on Oct 20, 2008
    New Friend:
Just fixed my washer with this thread. Checked for blockages and clogs by removing the pump from undeneth the machine. Saw no clogs. Ran the self diagnose, and error code 37 came up. Pump error. Ordered a new pump online. Replaced it. Works great again now. Problem solved.
Posted on Apr 01, 2017
I had this same problem and it turned out to be a pair of shorts that ended up between the machine chassis and the large plastic bowl rather than inside the bowl, and they had become stuck in the moving parts of the pump.
1. Remove the top of the machine by removing the two screws at either side of the machine (they are covered with caps which first need to be removed).
2. Visually inspect the area between the machine chassis and the large plastic bowl. Pay attention to areas close to the pump. Use a torch if necessary.
3. Carefully remove the clothing so not to damage any parts of the pump. Use a pair of kitchen tongs if necessary.
Posted on Oct 12, 2008
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
It's not the pump. There is a diverter valve right by the pump. It needs replaced. It diverts the water back into the tub when rinsing and out when draining. Its stuck on in
Posted on Nov 10, 2018
So my machine was stuck on 18 mins, was not doing anything, I read this thread then simply blew up the tube that lets the water out. and It worked I think something must be stopping it and it probs will happen again the Last machine we bought a new pump only to find a hair grip stuck in the old pump.
    New Friend:
  • 3 Answers
I just fixed a F&P GW612. If there is a foreign object stuck in the drain pump it won't drain at the rice cycle. I found a bent darning needle stuck in the motor drain pump.I lay the machine down on its side on a soft mat, removed the motor pump from underneath & cleaned it out. (You could find a foreign object such as a coin, cloth, rubber band etc. See You Tube videos on how to do this.)
Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle.
Posted on Sep 09, 2015
2 Suggested Answers
SOURCE:
watugot
  • 290 Answers
SOURCE: Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Posted on Oct 31, 2007
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washing machine
Without being smart...buy a new machine. It sounds as though the timer is dying...therefore slowing down...therefore extending cycle times. If that's the case, a new timer will cost about half the cost of a new machine.
May 06, 2012 | Fisher and Paykel Washing Machines
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Warning I have too many suds
Hi just read your posting.Now just a couple of questions.1st where is the machine draining the water to?Is it into the laundry sink or to another place?Have you removed the clothes from the machine?Have you tried putting a bucket or two of water manually into the bowl and put it to a spin cycle to drain the water out? Please reply with additional information and I can help you further.
Jul 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
22,833 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
