Where is the low pressure hose located on a 1998 saturn coupe
    Sergeant:
  • 340 Answers
Locate the compressor it will be the bigger line.
Posted on Jun 20, 2009
1998 Saturn Sc2 coupe Only drivers side low beam comes on passenger side off it has no power High beams work How can I fix this?
Find the break in the power wire for the low side. High beam works, ground is good. Low beam works on the other side, so you have power threw the switch and turn signal. Wires usually break close to the plug. Also check the plug for corrosion. White to a greenish color.
Oct 23, 2015 | Saturn Cars & Trucks
I am trying to locate the low pressure port on my 2000 Saturn LS. there is no cap on the only visible and accessible port I see. It is located in the front of the engine compartment (passenger side) but...
The high pressure port is much larger than the low pressure port. It is impossible to hook a charging hose to the wrong port. If the charging hose is leaking, it is either because it is not clicked all the way on the port or the charging hose connector is defective.
The high pressure port is located on the discharge hose just to the rear (driver's side) of the A/C compressor.
Jul 10, 2011 | 2000 Saturn SL
Where are the fuses for the dash board lights and the tail lights located in the fuse box on a 1998 Saturn coupe
There are two fuse boxes one i under the hood and the other is on the passengerside next to the center console.
Mar 06, 2011 | 1998 Saturn SL
I cant find the low pressur port on my saturn sl 1998 can u help me please
If you are recharging your A/C the recharge can dial hose will only fit on it, follow the lines from your A/c compressor
Aug 26, 2010 | 1998 Saturn SL
How to hook up the air condition refrigerant to the car itself on a 1998 saturn sl thankyou
You will need a hose to connect to the can of coolant and to the low side fitting in the car. There will be 2 lines coming from the A/C compressor, the low side is the line that is larger in diameter of the two. Follow that line and you will find the fitting to connect the hose to. I would get a hose that has a pressure gauge included.
Apr 23, 2010 | 1998 Saturn SL
I have a 1998 saturn sl1 with a code PO452 how do i fix it
CODE PO452 IS FUEL TANK PRESSURE SENSOR CIRCUIT LOW INPUT CONDITIONS.YOU COULD HAVE A FAULTY FUEL TANK PRESSURE SENSOR.
Apr 18, 2010 | 1998 Saturn SL
Locating the High side and Low side AC gas ports
Easy. find the compressor. The larger hose attaching to the compressor is the "suction" side. This is where you install the refrigerant.
The smaller hose, whether rubber or metal as it travels to the passenger compartment, is the high pressure side.
After installing refrigerant and as the compressor is running, the larger hose will feel cool and the pressure side will feel hot.
Jul 29, 2009 | 1998 Dodge Caravan
AC low pressure port location
hello,good day,you have a 210 model with v 8 engine,your high pressure connection is located at front of your condenser,beside your ax.fan,then your low pressure connection is located at engine walling near your vacuum hose for brake booster,right side ,standing in front,ty
May 13, 2009 | 1998 Mercedes-Benz C-Class
2000 Saturn LS Service Engine Soon Light
codes are for fuel system lean bank 1 and 2. low fuel pressure or innacurate mass air flow sensor could cause this. most common is mass air flow sensor.
Feb 20, 2009 | 2001 Saturn S-Series
Need location of thermostat in 98 saturn sl series
Front of the motor, low, in the fitting where the radiator hose goes into the motor; not the one on the drivers side. The fitting is rounded and is held on with two bolts.
Nov 26, 2008 | 1998 Saturn SL
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
