Question about Alpine MRD-M300 Car Audio Amplifier
E-3 comes up
I Know i have to eliminate the excessive currant but can anyone explain to me how to do so.
  • 655 Answers
Hello svjonny13,
Excessive current draw can be caused by a short in the wiring, especially the output. Also, an amp may draw excessive current when operated into a lower impedance load than it can handle.
Too low of a supply voltage may result in the amp drawing excessive current, especially when operated at or near it's rated output. Voltage multiplied by the current equals watts. So if the amp is trying to produce X number of watts, the lower the voltage, the more current it needs. A power wire that is too small or too long may have too high of a voltage drop. A high resistance in the ground connection can also result in a significant voltage drop. Again, too small, too long, loosely fastened, or perhaps corroded. I'd check all wiring
Internal component failure can also cause excessive current draw. In that case, the amp needs service.
Hope this helps.
Posted on Jun 17, 2009
I have a 2003 sopercrew with 5.4 The battery o was told tested good but it still is dead some of the mornings ? No lights , radio, or accessories left on
Possible intermittant internal short inside the battery causing this issue. The life expantancy of an automotive battery is 5yrs. Anything older can cause problems. Also possible intermittant parasitic draw causing the battery to deplete. If the battery is old I would suggest starting with a replacement and go from there.
Oct 25, 2015 | Cars & Trucks
2007 Kawasaki Eliminator 125 poor fuel mileage
Hi, Anonymous and the usual suspects are:
1. Excessive choke use.
2. High-speed riding style.
3. Idle speed improperly adjusted.
4. Dirty air cleaner element (may also affect idle speed).
5. Restricted fuel tank vent system.
6. Vacuum piston assembly malfunction.
7. Excessive accelerator pump output.
8. Plugged or restricted bowl vent.
9. Float level too high.
10. Loose carburetor jets.
11. Worn or damaged needle or needle jet.
12. Choke valve not seated or leaking.
13. Plugged air jets or passages.
14. Low air pressure in the tires.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
4 Reasons Sportbikes Get Poor Fuel Mileage
Why do motorcycles have low fuel economy Motorbike Writer Kawasaki Eliminator 125 Service Manual
OEM Parts for Kawasaki
2007 Kawasaki Eliminator 125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 20, 2014 | 2007 kawasaki Eliminator 125
Excessive high pressure ruptures new oil filter
Oil pump should have a pressure relief valve but hard to know since you're keeping the year, make, model, engine a secret.
Jan 12, 2018 | Toyota Cars & Trucks
How do electrolyte imbalances develop?
Electrolyte imbalances are caused from excessive ingestion, diminished elimination of an electrolyte; diminished ingestion or excessive elimination of an electrolyte. renal failure is the most common cause of imbalance.
Apr 22, 2013 | Health & Beauty
I have a yellow film inside the refrigerator. I
You have a seled system leak call for service this has a seven year warranty.
Nov 23, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Any extra`s tips to refilling antifreeze in hhr will be replacing thermostate ,when refilling anti freeze anything other than pouring in overflow jug,do i have to turn on heater or anything,is there anyway...
always run the heater on high it eliminates air pocket forming preventing heater problems. I like to run till just near operating temp then shutting off for a few minutes. Engine temp will increase and open thermostat. Then restart and continue to fill slowly till finished. It would take a page to explain why this is good to do but have been using this method for years & have had less fill problems than anyone else I know. Good luck
Mar 19, 2009 | 2006 Chevrolet HHR
2002 ford windstar 3.8 liter code PO402
I know this is a old post, but I had the same problem and it was the dpfe sensor. The EGR is almost never the problem with this code
Jul 15, 2008 | 2002 Ford Windstar Cargo
Led read out
E-3 The amplifier has been shut- down due to excessive current. Find and eliminate the cause of the excessive current, then turn the power off then back on from the remote control unit.
Jan 28, 2007 | Alpine MRD-M300 Car Audio Amplifier
Alpine MRD-M300 Car Audio Amplifier Logo
248 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
