2003 Ford Escape Logo
Andrew Nathan Posted on Apr 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The whole right side indicator signals do not work, front, on mirror, and rear, and do not work in hazzard mode either... is it the relay or it it a globe?
Stan Ford
Level 3:
Genius:
  • Ford Master 3,131 Answers
  • Posted on Nov 29, 2014
Stan Ford
Ford Master
Level 3:
Genius:
Answers
3131
Questions
Helped
905554
Points
9078
If one side works the flasher unit is ok it could be bulbs, a bad connection or a fault with the indicator switch
2 Related Answers
Anonymous
  • 1403 Answers
  • Posted on Jan 12, 2011
SOURCE: 2006 Ford Fiesta, Left side
yes,have an idea! when the turn signal works on one side or other really fast, you have a blown front or back blown turn signal light bulb.remove the back first,it's usually the one that blows fisrst,but not always! you may have to look or inspect the rear bulb. it will have a blown element in the bulb itself.look at the bulb for a very small wire inside of the bulb,if the metal ring inside the bulbs broken into.it will not work. unfortunatlly, you will have to remove one at a time. i would start at the rear,unless,you've hit something,or been stuck in snow from the front side. if you have been stuck in snow,i would go to the end that's been stuck and start there.other wise just start at the rear and check for a blown signal light bulb.it will be in the yellow portion of the turn light. the bulb that lights up the yellow portion of your tail light turn signal.if it's in the rear,you will need to access the bulb from inside the rear hatch assembly. if in front, you will need to remove the turn signal light. hope i've helped you! thank you for choosing fixya.com
richie9911
Richard M.
  • 155 Answers
  • Posted on Nov 05, 2012
SOURCE: no right side turn signal , indicator or right side hazzard
Possible multi function switch?
2answers
Had replaced turn singals bubls on my 2004 chevy venture van still wont. Work whats the problem PLEASE Thank YOU so much
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
• The Rear Turn Lamp
• The Turn Signal Indicator
• The Sidemarker Lamp
• The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
2answers
On 2004 pontiac montana what does fuse 7 control
7-BATT MAIN 1
60A
Fuses: •
CIGAR/DLC/APO FRT
• CLUSTER BATT
• CTSY LAMP
• ON STAR
• PWR LOCK
• PWR MIRROR
• RAP RELAY
• RR PWR SCKT
look below for above listed componet's , pull those fuse's one at a time till arc stop's ,then you found your problem circuit . Do you know where the I/P fuse box is ?
Fuse Block- I/P
Right side of the I/P, in the right front door opening
Fuse Block-I/P Label
Fuse Block-I/P Application Table Fuse/Circuit Breaker
Rating
Description
BCM PRGRM
10A
Body Control Module (BCM)
ENHANCED EVAP/AWD
15A
Evaporative Emission (EVAP) Canister Vent Solenoid, Clutch Pump Check Valve
CIGAR/DLC/APO FRT
20A
Auxiliary Power Outlet-Front, Cigar Lighter, Data Link Connector (DLC)
CLUSTER/BATT
10A
Instrument Panel Cluster (IPC)
CRUISE
10A
Cruise Control Module (CCM), Cruise Control Release Switch, Cruise Control ON/OFF Switch
CTSY LAMP
10A
DRL
10A
Daytime Running Lamps (DRL) Control Module
HVAC/DIC/DRL/HEATED SEAT
10A
Air Temperature Actuator-Left, Air Temperature Actuator-Right, Daytime Running Lamps (DRL) Control Module, Driver Information Center (DIC), Mode Actuator, Rear Window Wiper/Washer and Multifunction Switch (Heated Seat Switch), Recirculation Actuator, Relay Block (Rear Window Defogger Relay)
ELC/TRAILER
25A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Air Inflator Relay, Auto Level Control (ALC) Sensor
FRT HVAC HI BLWR
30A
Blower Motor Resistor Assembly
FRT WPR/WSHR
25A
Windshield Wiper Motor, Windshield Wiper/Washer Switch
HAZARD
15A
Turn Signal/Multifunction Switch
HEADLAMP
20A
Daytime Running Lamps (DRL) Control Module, Headlamp Dimmer Switch, Headlamp Switch
HTD MIRROR
10A
Outside Rearview Mirrors-Left, Right
HVAC/BLOWER
25A
HVAC Control Module
IGN1
10A
Body Control Module (BCM), Instrument Panel Cluster (IPC), Left Rear Side Door Actuator Control Module, Rear Object Sensor Control Module, Right Rear Side Door Actuator Control Module, Stop Lamp Switch
LH HEADLP HIGH
10A
Headlamp High Beam-Left
LH HEADLP LOW
10A
Headlamp Low Beam-Left
LH T/LP
10A
Tail Lamp-Left, Trailer Rear Wiring Harness
MALL/CLUSTER
10A
ON STAR
5A
Vehicle Interface Unit (VIU)
PASS KEY
10A
Theft Deterrent Control Module
PCM/ABS
10A
Electronic Brake Control Module (EBCM), Fuse Block-Underhood, Powertrain Control Module (PCM), Park/Neutral Position (PNP) Switch
PCM/CRANK
10A
PCM/PASS KEY/CLUSTER
10A
Instrument Panel Cluster (IPC), Powertrain Control Module (PCM), Theft Deterrent Control Module, Instrument Panel Cluster (IPC), Powertrain Control Module (PCM)
PWR LOCK
20A
PWR MIRROR
10A
Outside Rearview Mirror Switch
PWR QTR VENT
10A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Sensor, Rear Quarter Window Switch
PWR/HEATED SEAT PSD
30A
Driver Seat Assembly, Passenger Seat Assembly
PWR SLDG DR
30A
Left Rear Side Door Actuator Control Module, Right Rear Side Door Actuator Control Module
PWR WDO
30A
Window Switch-Driver, Window Switch-Front Passenger
RAP RELAY
10A
Relay Block (RAP Relay)
RH HEADLP HIGH
10A
Headlamp High Beam-Right
RH HEADLP LOW
10A
Headlamp Low Beam-Right
RR HVAC/TEMP CONT
25A
Air Temperature Actuator-Auxiliary, Blower Motor-Auxiliary, Blower Motor Relay-Auxiliary, HVAC Control Assembly-Auxiliary, Mode Actuator-Auxiliary
RR DEFOG/ HTD MIRROR
30A
Window Defogger Relay-Rear
RR FOG LP
10A
Fog Lamp Relay-Rear
RR PWR SCKT
20A
Auxiliary Power Outlet-Rear
RH T/LP
10A
Tail Lamp-Right, Trailer Rear Wiring Harness
RR WPR/WSHR
20A
Window Wiper Motor-Rear, Rear Window Wiper/Washer and Multifunction Switch
SIR
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM)
STOP LAMP
15A
Stop Lamp Switch
SWC BACKLIGHT
2A
Steering Wheel Controls-Left, Right
T/SIG
10A
Turn Signal Switch and Backup Lamp Relay
Right hand turm signal does not work ~
Sounds like the flasher relay in the fusebox under the hood
My indicator lights have stopped flashing,though my hazzards are still flashing
Because they are on two different relays. Check front and rear bulbs, if ok replace the turn signal flasher relay.
Rear and front signal lights are not working but my hazzard lights do work its not the fusees they are all good?
  • Your hazards and turn signals are on a separate fuses and different relays. Check both fuses and both relays. Relays should be under the hood. The schematic will be on the underside of the lid. Relays look like a little black box with 3 prongs for the terminals. They just pull right out.
Regards, Tony
I have a 1991 mazda 323 and the right front and rear blinker does not work however the leaft blinker does
When you turn on the right blinker does the indicator light come on? It could be a faulty turn signal switch. The turn signals are routed through the hazzard switch, sometimes you can switch on and off the hazzard switch several times and the turn signals could start working again...Hey it's worth a try..
2answers
My left indicator isnt working,the rest are though
need more info ??does it work with hazzards on ??all four lights?'
1helpful
2answers
2002 toyota corolla turn signal does not work (none of them work)
or you can maybe check if the connector is still in place, you can open the mounting around the vent, radio and hazzard button, the plug for all flasher is under check if it still plug first...
1helpful
2answers
Front and Rear Right turn signal lights would not work
the first thing i would do is replace the relay seeing the fuses check out ok otherwise there is a relay under the dashboard which could be the problem hope this helps regards Jim
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
