Question about Dell 946 All-In-One InkJet Printer
Solution for "dell 946 aio reads error 1203 replacment cartridge wont read"
    Sergeant:
    Champion:
  • 310 Answers
This is what I found on a Dell Community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Hope this helps
Ranjit
ranjit@supportminds.com
Posted on Jun 16, 2009
What is error #1203?
MY PRINTER WAS PRINTING AND ERROR #1203 JUST CAME UP AND IT STOP PRINTING.
Aug 01, 2012 | Dell 946 All-In-One InkJet Printer
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
Help me with cartridge error #1203 please
Ok it worth a try
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Apr 15, 2010 | Dell 966 All-In-One InkJet Printer
Will not fax says Error #1203
Good day! Error 1203 means that there is a communication failure between one of the cartridges and the pritner. Try these procedures to help you resolve the problem. 1. Power off
the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. If no go, 2. Power off the AIO
and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. Remove
both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on. If the error pops up, there is a hardware problem with the
printer. 3. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to
the middle of the unit. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. If the error still pops up, continue cleaning or
replace the cartridge. If no error, 4. Do step #3 again for the black cartridge. If error pops up, continue cleaning or replace black cartridge. If no error, print a test page.
Hope this fixes your problem.
Mar 22, 2010 | Lexmark X4270 All-In-One InkJet Printer
Aio dell 962 all in one cartridge error code 1203
Hi there
Please try this see if it may work.
or
Mar 07, 2010 | Dell 962 Photo All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Error code 1203 , what dose error code 1203 stand for in owners manule
It could be this
or
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 22, 2009 | Dell 946 All-In-One InkJet Printer
Dell 946 error 1203
In this Case just unplug the Power Supply from the Printer...........
Remove both the catridges from the Printer........
Move the Catridge carrier which holds the catridge back and forth for abt 20 times as fast as u can....
Now Turn the Printer On it will work fine.........
Good Luck...........
Apr 04, 2009 | Dell 946 All-In-One InkJet Printer
Message says cartridge error 1203 and it wont
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
Feb 23, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
What does error 1203 Mean?
Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. The procedures below will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
2 Open the top cover of the AIO and remove both cartridges from the AIO.
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat step 4. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 5.
5
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts .check the link for cleaning http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:590:0:0&framed=&docid=ENUS24064&relevance=0
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
Mar 11, 2008 | Lexmark P4350 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
214 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
