Question about Krups GMA1-42 Power Xtreme VI Work Top Blender
Krups GMA1 Blender
How do I remove the drive gear from a Krups GMA1 blender?
2 Suggested Answers
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
How to disassemble krups gma1 blender
Myron's tip about the need to unscrew the grey rubber coupling is correct, but I was unable to grab the post and hold it still, even though I was using narrow needle-nose pliers. I just could not get underneath the rubber coupling. I ended up cutting the rubber piece off the steel cord inside the coupling, which exposed the threaded post. I could hold the post stationary from above while I unscrewed the steel cord. My old coupling was stripped and worn out, so it did not matter. A new coupling can be ordered cheaply.
I found that it was not necessary to open the housing of the whole appliance as long as you can hold the post stationery. And even if you can't grab the post from above, opening the housing won't help because it won't come off until the coupling is removed at the top.
If you need to open the appliance for anything else, Myron is right, you need to remove the 4 rubber boots on the bottom to expose the screws. The screws are so-called temper-proof screws for which you need a special screwdriver. The screws are called "pin-in-head-star". But removing the 4 scows is not enough. You also need to unscrew the coupling at the top.
Jan 06, 2013 | Krups GMA1-42 Power Xtreme VI Work Top...
How do I change the serrated drive of my blender?
Hello, igriffing
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 02, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
Aug 12, 2011 | Krups 572 Power Xtreme VI Work Top Blender
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Apr 08, 2009 | Krups 239 Power X Plus Work Top Blender
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
A blender parts
You can most likely find all kind of blender parts at www.thegourmetdepotco.com. I just bought a Krups blender rubber drive gear from that online store. It's the best lowest price, compared it to Amazon.com too. Try it.
Nov 20, 2008 | Blenders
Ed,
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
Repairing the blender:
My guess: You worked the motor too hard on your last blending session and it overheated. That will cause a thermal fuse inside to cut off. The blender won't work again until you replace the fuse but otherwise it should be fine. The fuse looks like a white diode and it will be attached tightly to the motor with a nylon strap (so that it can pick up the heat of the motor). The leads to the fuse are shielded with heat resistant nylon wrap. You will need to remove the rubber drive gear in order to remove the plastic house so you can work, although if you are really handy you might be able to at least test the unit by only removing the plastic bottom on the base unit.
To remove the plastic housing, remove the little rubber feet and then remove all of the screws on the bottom of the unit. You may need to buy a bit set for tamper resistant screws (I ***hate*** those), I don't remember. When the bottom is removed, you will see that the there is a screw head on the bottom of the central motor shaft. You can use a screw driver here to hold the motor from turning, then you can carefully use a pliers to unscrew the rubber drive gear on the top of the base unit (try not to damage the rubber). With the gear removed you can get access to the wires.
To test the fuse unit, just check its continuity. Short=good, open=bad. To further test, short out the fuse with a jumper cable and your blender should work.
EPO (Electronics Parts Outlet) in Houston, TX, has the replacement fuse unit. I don't know that they like mail order.
May 13, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Mar 12, 2008 | Blenders
Krups GMA1-42 Power Xtreme VI Work Top Blender Logo
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
