Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
We just bought this house and the fridge that came with the house is a whirlpool designer style. The problem we are having is that it's leaking water all over inside the fridge and it's coming from the ceiling of the fridge that looks like vents or something from the freezer. Just wondering if anyone has any idea before we call a tech. Thanks a bunch
  • knodel Jun 16, 2009
    thank u so much. I'll give that a try.
  • 72 Answers
This is a common problem with old top mount refrigerators. The foam between the the two cavities starts to break down and sweat due to the differences in temperature between the two cavities. You can try emptying the unit, turning it off for a couple of days and leaving the doors open giving it a chance to dry out, if the condition returns after a short amount of time, then it is time for a new refrigerator, there is no cure for the breaking down of the Styrofoam inside the unit
Posted on Jun 16, 2009
I just rented this home in NJ and the landlord gave us a whirlpool designer style refrigerator. Dont know the model, but it also can make ice if hooked up when I pulled it out, but it is not. However, the freezer is making my ice cream to turn into smoothie. Also it is seems the bottom portion of the refrigerator is only cool not cold. It started about 2 days ago. What should we do. Please help. We do not want to loose our food.
Posted on Apr 28, 2011
Why does water filter leak when tightly connected but not when loose?
It makes sense if there is a crack in the filter housing that is made more severe by tightening the fitting. Also, a fitting could be stripped from overtightening.
Aug 11, 2015 | Whirlpool Refrigerators
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Where is water filter??
You have to check if it has a pipe that you connect to external water supply. The filter is connected to this pipe.
Jul 28, 2013 | Refrigerators
My house flooded this week causing damage to all flooring. What can cause water to suddenly come into the fridge? When water was turned back on there was water flowing under the fridge? Would a filter...
There are a number of things that would cause this, including the inlet valve and filter. However, a cracked filter is by far the most common cause. Remove the water filter and if it no longer leaks, the filter is bad. If it continues to leak, it is likely the filter housing that is the issue.
Sep 16, 2010 | Whirlpool ED2FHEXN Side by Side...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
Strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Jan 04, 2009 | Jenn-Air JCB2388G Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
316 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
