Question about Car Audio & Video
How do u get the old tape deck out? i tried taking the plastic piece out but around the cig. lighter and the light switch it wont move? is there any clips or screws holding it?
    Problem Solver:
  • 17 Answers
Whats the model of the car
Posted on Jun 18, 2009
    Problem Solver:
  • 4 Answers
Look (feel) on the side of the deck and see if theres a screw if not it may be clipped on and there should be a screw going into the little cubby either above or below the deck. i just did one that had a plate about 6 inches long and like 4 screws on one side.
Posted on Jun 17, 2009
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
I dropped a Penny in cigarette lighter on my 2001 acura rl now the radio doesn't work and fuses appear fine
Some radio power sources also tie into the cigarette lighter and power adapters. You mentioned fuses appear ok, if you dont have a test light to test both sides of the fuses try swapping the fuses around from another location and see if that changes anything.. Oh and if the penny is still in the lighter try a ball of tape of the end of a pencil to pull it out.. Look for a fuse listed aux. power or radio/cig lighter. Most likely the fuse is inside the car not under the hood..(usually)..
Apr 20, 2016 | Acura Cars & Trucks
Tape is slow and whirring noise
Alex somebody technical will have to look at what is wrong with your deck. What is the shape of this piece of plastic I tried to service a Nakamichi the other day and the reason for the deck to burn one of the motors from a sticker that was used for the identification and it jammed the mechanism up. It sound as if there is a part from the Pause control if this is one of the units in those made in China after about 1990
May 28, 2013 | Technics RS-TR575 Single Dual Cassette...
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Feb 18, 2012 | Sony TC-WR565RM Single Cassette Deck
Hi, I need to replace the cigarette lighter in my 2005 Mazda 6. I use a cigarette phone mount and the current cigarette lighter hole moves when the mount is placed in and a small piece of plastic has...
Before replacing lighter socket, try gluing it with super glue. Sounds like your only problem is that socket is moving because of broken plastic. Or you can buy aftermarket accessory plugs from autoparts stores and you can get them with up to three outlets for multiple plug ins.
Jan 07, 2011 | 2005 Mazda 6
2005 Dodge Caravan radio and clock is dead
check the cigerette lighter or power socket fuse. then check them all because some fuses feed other fuse and are not labeled as such. there under the hood and there is one that may have a plastic cage around it its the one that the dealer personel are supposed to push down when taking delivery of vehichle it turns all that stuff of so battery wont go dead in the stock yards, it may have popped from the cig lighter or power port
Apr 28, 2010 | 2005 Dodge Caravan
I cannot get my vhs tape to eject and i don't want to take it apart.
Try taking out the power cable from wall and the plug it back in and keep hitting eject if it does not want to then unfortunatly there is noway to get it out unless it was forced out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 28, 2009 | RCA DRC8335
Belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
May 21, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Radio intermittently cuts our
hi you will have to remove the the seering cowls clocks surround the surrounds that go round the radio and heater controls centre consel around gearlever cig lighter surround ect [ not an easy job ] give yourself 2-3 hours because these radios are screwed to the frame behind all this and unless you take the heater controls off they are awkward to get at yates210456
Aug 25, 2008 | 1997 Honda Accord
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
