Question about Casio Exilim EXZ75 Digital Camera
Battery won't charge, the charger blinks red and the camera lens won't extend
I contacted the manufacturer and they immediately sent out a new lithium battery. I received the new battery in 3 days, charged it, and the camera now works like new.
Posted on Jun 24, 2009
Means the battery is dead and will not take a charge. they run themselves down even when not in use to promote good charges...but you have to charge them now and again between periods of use to prevent this technology from draing the thing dead.
Posted on Jul 12, 2009
SOURCE:
My battery charger , olympus LI-40C blinks red and does not charge battery
Buy an el-cheepo battery charger kit and charge the batteries.
the olymup charger doesn't like non genuine batteries.
Dec 30, 2011 | Olympus FE-20 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Casio digital cammera
are you sure the battery is charged?
put the battery on the charger.
is it blinking red or does it stay red?
if it's blinking red, it won't charge correctly unless you do this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
Sep 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It wont turn on and there is a red flashing light
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
Aug 04, 2008 | Cameras
Battery won't charge on Kodak Easyshare V550
I don't think its the battery. My just did this this week..If I slide the Favorites switch up (switch by hand strap mounting hole) I can view the pictures in it, but it won't use in photo mode, Lens won't extend, and it shuts off?
Jul 08, 2008 | Kodak EasyShare V550 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
390 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
