Question about Brother ML-300 Typewriter
Removing the cover
I want to replace the ribbon cartridge, but not break the boss's typewriter.
    President:
  • 1,185 Answers
Click on the link below and go to page 41 , that will tell you how to do it
http://www.manualnguide.com/dl/11876/
Posted on Jun 16, 2009
Brothers ax
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Dec 12, 2013 | Brother EM-430 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
The ribbon does not roll as you type so the ribbon wears in one spot. Seems to be on the cartridge base correctly.
put a mark on the gear that turns the ribbon (pen or sharpy) and type with the ribbon off (you may have to close the cover to do this. and watch the gear to see if it turns..if it does, you have a defective ribbon if it doesn't, you have a defective typewriter that need professional help.
Feb 17, 2011 | Brother GX-6750 Typewriter
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
Brother typewriter
make sure you power on the typewriter and space bar carrier until middle of bar. flip open cover and put ribbon in rear end first then push front to lock. i have to then turn orange knob on top of ribbon cassette in direction that arrow points just to tighten ribbon and that usually will lock the ribbon cartridge if it lock with first push. also, the ribbon itself goes in front of the 2 guides that stick up higher than the rest. hope this helps. if not you can look at brother website under that model and look at manual. it shows you how.
Feb 03, 2009 | Brother GX-6750 Typewriter
Ribbon retainer clip installation??
Possibly came from the ribbon cartridge. Try another ribbon.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 27, 2008 | Swintec 7040 Typewriter
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
Brother ML-300 Typewriter Logo
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
