Question about Kenmore Refrigerators
Refrigerator won't stay cold
It is model#596.7914992 the freezer which is on the bottom it's ice on the back of the wall, then the refrigerator starts to warm up. if we turn the unit off and let it defrost then it runs correct for about one week and it happens again
  • Kenmore Master
  • 4,655 Answers
I think there is something incorrect in the model number. Close but not close enough. Can you take some digital photos of your model. I know it is a defrost problem, but because the number is incorrect I cannot point you in the right direction. If you have a defrost timer or a adaptive defrost I'm just not sure. Thanks, Sea Breeze
Posted on Jun 16, 2009
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
KENMORE REFRIGERATOR WON'T COOL ON BOTTOM BUT FREEZER WORKS BUT HAS ICE ON BACK WALL
needs fan replaced, there are a couple of plastic strips down the sides of the bottom plate, remove those to expose screws remove bottom pan then back wall fan will unclip from wires local appliance store should have one avaiable
Jul 04, 2012 | Kenmore Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
The refrigerator part is not staying cold. The freezer is wrking correctly and is freezing food. I vacummed all the dust out of the back but the refrigerator is not staying cold. It is running...
This can be a defrost problem or the fans may not be running. If the fans are not running then check the fans. I would need the model number to tell you if you have an electronic model or not because checking the fans is a lot different.
If it is a defrost problem the back wall of the freezer will be covered with ice.
This website has very good info on thses problems
http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 24, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
