Question about HP OfficeJet Pro k550 Printer
ONLY PRINT 25% OF THE PAGE AND STOP. THE PAPER ICON FLASH YELLOW
Check if some of cartridges is low on ink.
Posted on Jul 03, 2009
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
I have installed new cartridges but paper comes out blank
Hi Khalid,
Make sure your printer is set as the default printer on your PC.If you were printing many pages,try selecting the current or the page with the text only and try to print it.Check paper size settings,orientation,layout and printable area in your software and make sure they're in line with the paper you're using.If problem not solved,then you may need to clean the printhead to unclog the nozzles so that they enhance smooth flow of ink.
  • Connect the printer to the computer and turn it on.
  • On the taskbar of your PC,right click on the printers icon.[If there's no icon,go to your printer properties window and then click on the maintainace tab.Select on the head cleaning option].
  • Select 'start' on the headcleaning pop up window that will appear.
  • The printer will starting making noise and the green light will start to flash.
  • After the cleaning the green light will stop.Select 'print nozzle check pattern' and then click on print.[make sure there is a loaded paper in the tray].
  • Check the printouts.If gaps and lines appear on the paper,click 'clean' and if they're ok,click 'finish'.
Hope this helps.Thanks!
Please rate this answer.
Dec 01, 2011 | Epson Stylus C86 InkJet Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
How do I "right clk explain. point icon" to open it up?
hi  check your pickup roller under the tray. pull out the tray and see just above it if the pickup roller is not broken or warn that can be your problem most likely. the light flashing jams it is like a jam occur because no paper was picked up by the feed assembly of the printer and there is a flagto tell it if a page came through.
Dec 27, 2008 | HP LaserJet 1320 Printer
My canom laserbase mf3110 print only one page
Well, when it comes to PDF files i found a solution. When u click the "print" icon, u get the "print" window. If u leave it as is, u will get a format/paper size error when trying to type several pages, as described by u. However, if u unmark the "Choose paper source by PDF page size", it will print as many pages as u want.
So...If u have trouble printing pages, it may work if u turn your pages into PDF format and follow the instruction above :)
Dec 20, 2008 | Canon MF3110 All-In-One Laser Printer
Printing with 190gsm paper
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found www.oki.com.
Dec 31, 2007 | OKI C5200n Laser Printer
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
HP OfficeJet Pro k550 Printer Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
