Question about OKI Pacemark 4410 Matrix Printer
Paper jam when there is no paper jam
While printing the printer will quit running and in the display it will say paper jam. Yet time after time there will be no jam and then an auto gap error will appear.
R300 Epson stylus says paper not set correctly yet it is. Any recommendations
Posted on Jun 16, 2009
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
The display says there is a paper jam, but there is none
Sounds like the printer need to be "reset"
Cancel all print jobs.
Disconnect the printer from your computer
Turn power to printer off and unplug it.
wait 1 min, then reconnect printer to your computer.
then plug printer back in and turn it on.
Start your print job over.
Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
Start print job again.
Should the problem still exist contact support at Samsung via the links on their homepage.
Good luck.
Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Displayed fault is 'Paper Jam'
you amy need to reset your printer let me no if you need the info on how to reset your printer
Sep 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
OKI Pacemark 4410 Matrix Printer Logo
431 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
