Question about Cobra Radio Communications
ABS, Brake warning, Engine check lite up. Tach, Speedo, mileage
2009 Honda Accord. I am told that the remote tire monitor system or ECM (what is that) can be affected by a single CB radio transmission. (outside the car antenna and radio is in a metal box under driver's seat and the antenna is fed with groounded-shield coax!!) When told that my 1997 Toyota Avalon had a 100 watt ham radio and 12 watt SSB CB, the tech said, ''yeah but it does not have the tire monitor system.'' Mabe that is why I have never seen a police car with all their electronic gadgets being a Honda. Walt.
  • jcw7qis Jun 16, 2009
    I don't know if there is a problem with the TPM...I just got a call which said they had taken an ECM out of another car and put it into ours. That the dash panel display has apparently returned to normal. If the tire units are transmitters then they should QRM (interfere with) the CB receiver. That has not happened.
    Since I might have the CB plus a 50 watt ham station in the Honda, what do you receommend that I do to prevent this ECM failure....With about 700,000 ham radio operators and who know how many CB operators and who knows how many FRS (family radio service) ops there are...seems that Honda is alienating a large market if they can't prevent interference from owners 2-way radios.
    Your comments please. Walt.
    Top Expert:
  • Cobra Master
  • 81,400 Answers
THE SENSORS FOR TIRE PRESSURE ARE INDEED MINIATURE RADIO TRANSMITTER'S, THE FREQUENCY OF THAT SIGNAL IS NOT IN THE SPECIFIED IN THE FACTORY SERVICE MANUAL, SO YES IT IS POSSIBLE FOR THE SIGNALS TO BE INTERFERED WITH BY A CB RADIO TRANSMISSION, BUT THE TRANSMISSION SOURCE WOULD HAVE TO BE VERY CLOSE. ECM STANDS FOR "ELECTRONIC CONTROL MODULE", THE SYSTEM IN THE CAR THAT MONITORS TIRE PRESSURES IS CALLED A "TPM", OR TIRE PRESSURE MONITOR, IT CONSISTS OF 5 SENSORS (4 TIRES AND SPARE) THAT ARE RADIO TRANSMITTERS AND A RECEIVER THAT RECIEVES IT'S SIGNAL FROM THE WHEEL MONITORS THROUGH THE ANTENNA OF THE CAR. DO U HAVE A PROBLEM WITH THE TPM SYSTEM?
Posted on Jun 16, 2009
  • Marvin
    Marvin Jun 16, 2009
    POLICE CARS HAVE TON'S OF ELECTRONICS'S, JUST LIKE YOUR CAR, I KNOW BECAUSE I HAVE WORKED ON DOZENS OF THEM, THE ELECTRONIC CONTROL MODULE (ECM) IN YOUR CAR IS SHIELDED AGAINST OUTSIDE RADIO INTERFERENCE, IF IT WASN'T EVERY TIME YOU WENT UNDER A HIGH POWER TRANSMISSION LINE YOU WOULD HAVE A PROBLEM WITH THE SYSTEM, THE RADIO OUTPUT OF SUCH POWER LINES IS MORE THAN YOUR CB RADIO, AND EARLY SYSTEMS DID SUFFER FROM THIS INTERFERENCE, BUT IT SHOULD NOT AFFECT YOUR CAR, I SUSPECT IF THE ECM HAS A PROBLEM IT IS JUST COINCIDENCE AND NOT YOUR CB RADIO THAT CAUSED THE PROBLEM, IF THAT IS WHAT THEY ARE SAYING 35 YEARS OF ELECTRONIC ENGINE CONTROL WORK SCREAMS AT ME THAT THEY ARE BLOWING SMOKE ON THIS THIS. mY CREDENTIALS? 40 YEARS AS A PROFESSIONAL TECHNICIAN, CERTIFIED MASTER TECHNICIAN IN ALL PHASES OF AUTO REPAIR.
Vsa,brake, abs linght on and D flashing when I turn on key
You need to have the vehicle scanned for fault codes and then the causes of those codes diagnosed.
You will need to have this car checked out by a professional with the right diagnostic equipment for Hondas. The Vehicle Stability Assist (VSA)***, brake and ABS warnings may just be due to a failed sensor or sensors but you need to have a proper diagnosis carried out so the causes can be identified and any failed parts replaced.
The flashing D light relates to the auto transmission and may well be a caused by a faulty sensor on the transmission or something else. The correct scanner should throw up any fault codes being generated. In the meantime if your Accord model has the engine bay filler tube and diptstick for the auto transmission , check your fluid level in the auto transmission.
***VSA..................
http://techinfo.honda.com/rjanisis/pubs/OM/RL0000/RL0000O00189A.pdf
Nov 19, 2015 | 2009 Honda Accord
ABS/TCS lights on 2002 Honda Accord Coupe EX V6. Have high quality OBDII Scanner. Should the on board system report the problem to the scanner?
Only if the warning light showed on the dash...most often these abs sensors get clogged with brake dust or dislodged during wheel swaps if the pads are fine and fluid level correct...first check the brake pads then the disks and clean the sensors with an old toothbrush and reseat, also check the fluid level on the abs system.this should clear warning light.but any error codes stored on ecu need to be cleared using obd.
Nov 10, 2015 | 2002 Honda Accord
Service brake system warning on driver info center on dash
Possibly a defective ABS sensor, or low brake fluid. Recommend a reputable mechanic to assess the issue.
Oct 12, 2017 | 2004 Chevrolet TrailBlazer
I also got code u0122 on honda accord 09 showing abs,vsa,and brake light need help please!
code u0122 fcan malfunction ecu to vsa. dealership has to fix.problem in your ecm and vechicle stability assist.
Nov 08, 2011 | 2009 Honda Accord
What does the B1 warning light on Honda Accord mean? and how can it be reset
This is a service required warning light
B" indicates the following services are due:
- Change engine oil and filter, inspect brakes, check parking brake adjustment - Inspect : steering components, suspension components, rubber boots, brake lines, fuel lines, exhaust system, fluid levels and conditions "1" indicates: - Rotate tires
Sep 22, 2010 | 2007 Honda Accord Sedan
Our 2003 Ford Windstar speedometer is intermittent, and today the tachometer needle pegged and got stuck in the PRND mechanism. I was able to push the tach needle free but it no long works. Any...
I HAVE RUN ACROSS SOME WEIRD STUFF ON THESE VEHICLES EX. TACH, SPEEDO, RADIO ,LIGHTS AND SO ON ,,WATER /MOISTURE WAS FOUND IN THE TRANSMISSION RANGE SWITCH ( NEUTRAL SAFETY SWITCH )CONNECTOR ,,,THAT WAS CAUSING SOME MAJOR TECHNICAL DIFFICULTIES ,I REPLACED THE SWITCH AND CONNECTOR AND THAT SOLVED IT , , I DON'T KNOW WHAT ALL THE SYMPTOMS ARE FOR THAT PROBLEM BUT I WOULD DEFINITELY CHECK IT OUT ,,,
GOOD LUCK
Aug 15, 2010 | Ford Windstar Cars & Trucks
How many indicator lights are there and where are they for 2009 f150 supercrew
Item Part Number Description 1 — Tachometer 2 — LH turn indicator 3 — Oil pressure gauge 4 — Overdrive (O/D) off/tow haul indicator 5 — Engine temperature gauge 6 — Air bag warning indicator 7 — Safety belt warning indicator 8 — Fuel gauge 9 — Tire Pressure Monitoring System (TPMS) warning indicator 10 — Speed control indicator 11 — Transmission temperature gauge 12 — RH turn indicator 13 — Speedometer 14 — Malfunction Indicator Lamp (MIL) 15 — Message center indicator display area 16 — High beam indicator 17 — ABS warning indicator 18 — Brake warning indicator 19 — Message center display area 20 — Anti-theft indicator
Feb 27, 2010 | 2009 Ford F-150
Abs honda 1995
if the abs light is already on the abs system is already bypassed, and your base brake system should operate without the abs working properly as long as the red brake warning light is not on
Nov 25, 2009 | 1995 Honda Accord
1997 GMC Jimmy braking problem
the abs control unit controls the speedo (tach) also tells the cruise signal. abs should be fixed or replaced for any of these to work properly with the abs system not working you have no signal to the ecu to say what fuel air mix is for the speed you are doing and will think you are idling.
Jun 07, 2017 | 1997 GMC Jimmy
ABS warning light
To my knowledge, the ABS light coming on indicates that the system has been disabled for some unknown reason(s). This would then translates to your vehicle having only standard/conventional power brakes, but brakes you will still have.
The correct procedure would be to have your ABS Brake Code scanned and interpreted.
The ABS warning light could be triggered by faulty sensor in any of the wheels or damaged wiring/connector or worst case scenario defective ABS module, pump or motor. Alternately, you try to fill the reservoir up. Normally, there would be a rubber cap andanother plastic cap under it. Add Honda brake fluid with the engine running. It would be preferable to do it slowly as to allow the air bubbles to escape. Additionally, pls check for any sign of leakage. If for some reason it would considerable fluid has to be added, it may be necessary to bleed the system. Pls reference this page for the procedures.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | 1997 Honda Accord
Radio Communications Logo
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
