Question about HP DeskJet 882c InkJet Printer
No power on. Power cord is pluged in OK.
No power on. NO light at power button. Power cord is pluged in OK at both ends. Is there a fuse?
    Guru:
  • 224 Answers
Not necessarily.
connect the printer directly to the walljack.
If the printer still does not come on then try a diffrent walljack without the surge protector.
If this still does not work then try with another power cable now if this still does not work.
Sorry to inform you but your printer has just died on you.
But call in to hp at 1800 474 6836 and now since your printer is obsolete ask the agent who answers your call for an upgrade.
cauz upgrades usually get atleast a 40 % discount amazing right????????
its a toll free number
Posted on Jun 16, 2009
Cobra xrs 979 wont turn on The light on the power cord is on (fuse is ok) but the radar detector will not turn on anymore. Any ideas? Thanks!
I have a Cobra ESD-9117 that wouldn't turn on. There was power at the plug end. I took it apart and took the power/volume button off. I used a magnifying glass and found the contact for the power must have bent from all the years of use. I bent it back and all is good again.
Oct 29, 2016 | Cobra Vehicle Parts & Accessories
My cig lighter dose't work in my 1992mitusbishi Galant
possible blown fuse or bad ground check wiring to make sure all wires are pluged in if so replace lighter
Feb 08, 2016 | Cars & Trucks
On my Panasonic model th42px75u. no power. When I press the power button, I hear a clicking sound in the power supply area. Checked both fuses. They're good.Thoughts?
Re you getting the standby red light when you switch on the power??????? If not, then I will advise you to check with another power cord which will confirm you that old power cable is defective. If so, check all the connections i.e. power plug, wall socket and the TV end. If all these are OK then the trouble lies with your switch. It is not making contact though it may be giving clicking sound. Have it changed since you have already checked the fuses.
Aug 07, 2011 | Panasonic TH37PX60 37 in. Plasma...
My dell e310 will not turn on
Check the power cord make shure both ends are not loose. Check the switch on the back of the tower. If the computer is pluged in to a power strip check the surge protector most have lighted switch and a reset button. If no power at the wall outlet check that a wall switch doesn't control it and is on. Check circut breaker Or fuse pannel.
Hope This Helps
Please leave feedback
Nov 16, 2009 | Dell Dimension E310 PC Desktop
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
I have a MY BOOKS ESSENTIAL EDITION. I can not get it to work. The light doesn't come on or anything. I have a power cord pludge into the wall and the other end is pluged into the my books. Then the USB...
there is no problem with the laptop
certainly
even if the cord fit correct it does not mean that the cord ik
why sont u try a different cord????
Oct 10, 2008 | Computers & Internet
GE. Microweave Oven, Model JVM 1090
If your microwave won't start and the display is blank and unresponsive, the issue may be with the ceramic fuse. This part protects other microwave components from power fluctuations, and causes a complete loss of power when it fails, meaning your microwave won't work. To access the ceramic fuse, located inside the cabinet near the power cord, first unplug your microwave. Use a multi-meter to test the continuity of the fuse. They look like this:
If the oven will not power up, but you are getting some display lights ... then it could be a thermal fuse in the back or a faulty door switch.
Helpful?
Good luck on your troubleshooting!
Mar 04, 2018 | Ovens
T.V. Orion
Goose456:
What type of Combo?
TV & vcr
TV,vcr,dvd
Does the TV turn on when u shob in a VHS tape?
Electricity is dangerioius ::
UNPLUG POWER CORD
open back, facing the back of TV, on your RIGHT, look to see if there is a fuse. BEFORE touching anything, take a screw driver, (anything metal) and place it inbetween metal BLADEs at end of AC cord. [of cause the AC plug is NOT pluged into the wall socket] ( this is to get any electircity still in the ckt. discharged!)
[Don't be offended!!] If u know how to use a ohms meter, test fuse or replace it with the exact value (Voltage & current)
Try that for now::
May 07, 2008 | Televison & Video
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
Open Questions:
HP DeskJet 882c InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
