Question about Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television
LC-45GX6U AVC TU-GD10U-T box does not power up. LC-45GX6U display showes white raster. Please help me.
  • 4 Answers
The DC/DC converter went out on your set. When you take the top off of your AVC box look for a 4" X 5" circuit board mounted on the front left corner. I have seen these fail causing you white screen. Order the part from your local Sharp service center. Part # RDENCA089WJZZ
Posted on Jun 17, 2009
  • Mark John Lamprecht Sep 19, 2012
    bryansied....it has been over 3 yrs since you posted and I took your advice here on Sept. 17, 2012 and you were 100% correct once again. Can't thank you enough! God Bless Ya! Mark John
  • adam schemerhorn Oct 12, 2012
    is there anyway someone could show step by step directions how to do this. pictures would be great. powpow_09@yahoo.com
Bryansled is 100% correct. I had the same problem, and was told by the repair shop it would cost about $500 and it was probably better to buy a new TV set. I was skeptical at first because the part costs about 150 bucks. That's a lot of money if it doesn't work. But I figured WTF, just try it. Easy to install and it worked right away. Bryansled, I can't thank you enough.
Posted on Jan 07, 2010
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have a Sharp LC-45GX6U Display & TU-GD10U-T AVC box, and only get a white screen on the display. I've been told that I can bypass the AVC box altogether, and just go to the dispay via HDMI. What...
I too have the same problem with the DC-DC board on the Sharp AVC. But I didn't spend the $134 for a replacement board (MCM or Newark).
Instead, I used the reflow technique by placing the circuit board in the oven for 7 minutes at 475F. You need to cover the plastic header connectors (about 7 of them) with foils to protect them from direct heat (and melt). Take the board out of the oven and give a little pressure on all the ICs while the board is hot. Let it cool down and voila! The TV is working again...
Apr 03, 2011 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
My Sharp LC-45GX6U gives only a white screen when I turn it on.
Can you guys please elaborate on what the work-around was for this issue?
Feb 19, 2011 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
The screen and the module both are showing red lights . The screen will not show a picture and I have tried to reset. Any options?
Press the VOL+ and Channel - button on the set and than the power button while holding the two buttons.
If the set starts then the fault is the error counter wich must be reset to 0. Max is 5 faults,if a sixth error is measured the set stops.
Nov 02, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
LC-45GX6U
Make sure that system cable is not lose.
Oct 22, 2009 | Televison & Video
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
TV Repair question
i would replace the video and power board inside the unit some of these units with the help of a flat head screw driver just pop off.
Jan 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
AVC BOX PROBLEM
I have had very few problems with the AVC boxes with this model and find most times the shut down is due to a failed power supply mod. in the tv.
Jan 15, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
No AVC media box
You should be able to use this with only the DVI connection as just a large monitor. You can use a DVI to HDMI adapter as I do believe the display is HDCP compliant. Many AV receivers will upscale to the necessary 1920x1080p resolution that the display needs.
Oct 29, 2007 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Display powers of with power up of AVC
This is the problem with my LC-37HV4U. I plug in the AVC and the tv/monitor and I get both red power lights (not blinking) but no green lights, sound, or picture. I mean the tv screen stays black! It seems like their is no communication between the AVC and the monitor. I thought at least the screen would light up when the power light came on and being it has it's own power source. This tv is driving me nuts!! Can anyone please help?? Thank you.
Jul 29, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television Logo
1,558 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
