Question about HP D1560 Deskjet Printer InkJet
HP DeskJet 1560 - multiple paper feed
I just bought a new DJ1560 printer, worked fine, until I tried to print a double-sided document. The printer permanently feeds multiple pages, permanently means about 90% mis-loads. One sided printing works acceptable, approx. 1-2% of misloads. The printer is new, printed less than 500 sheets. I cleaned the feeding mechanism several times, but this feeding problem is like a plague, I cant fix it.. Im working in a computer store, im repairing computers and printers daily, but this is a problem I really CAN NOT SOLVE, I will be pleased for any advice.
Thanks, Marian from Slovakia.
  • Mari?n Bra?ok
    Mari?n Bra?ok Jun 16, 2009
    Thanks for post, the site you linked was the first I googled, i found there a general solution on my problem:
    "Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together."
    Ridiculous. There should be a warning in the printer overview "You have no chance of duplex print"...
    I`m used to fan the paper everytime Im filling the feeder, its not the problem.
    I tried to roll the paper before I inserted it into the printer, so the paper had an upturned "U" shape, results were better, but not enough, cca. 20-30% of mis-loads.
    Putting a fan over the printer might be a good idea, I`ll try it out and I`ll give a post as soon as I`ll have some results.
    President:
  • HP Master
  • 1,996 Answers
This link may not help you to print duplex, but it will possibly explain why you're having problems...Make sure you fan the paper before loading it. You might try putting a fan on it to dry out the ink as it prints...or try a heavier paper. Good luck! If you google duplexer feed problem you'll see this is the subject of numerous patents and attempts to resolve the very difficulty you are having.
(Maybe another of the same model would work better? Hp should exchange it if it's not working, no?)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
When paper is feeding into the printer it takes to many pieces
If the printer is picking up multiple sheets of paper, follow the recommendations below:
  • Keep more than 10 sheets in the In tray.
  • Ensure media is not loaded too far and extending past the In tray.
  • Store all media in a dry, cool place. Humid climates will see this issue more often.
  • Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together.
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
  1. Remove the media from the In tray.
  2. Fan the edges, re-square the media, and reload the media properly into the In tray.
  3. Slide the paper width guide to the right until it stops at the edge of the media, then push the paper length guide towards the paper until it stops.
  4. NOTE: Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door. Remove the rear-access door (if applicable) and clean the internal rubber rollers with a soft lintfree cloth moistened with distilled water. Wait until the rubber rollers dry and replace the rear access door.
  5. Verify that the correct media size and type is selected in the printer settings along with the appropriate quality.
  6. If this issue still persists, try a different type of paper.
Aug 26, 2009 | HP Deskjet D1455 InkJet Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
HP D1560 Deskjet Printer InkJet Logo
321 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
