Question about Philips 19PFL3403D/27 19 in. LCD TV
How to scan for new digital channels small Philips flat screen
Hi - would like to know how to scan channels now that the conversion to digital has taken place.I've played around with the options on the menu, and "scan" doesn't seem to be there.My TV is a Philips 19-inch 19PFL3403D LCD TV and it is getting some digital channels but not all.I live in midtown NYC.Thanks :-)
    Sergeant:
  • 280 Answers
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Posted on Jun 16, 2009
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
How to reset philips 24pw60006/05 for digital changeover
typically you will press the menu button on your remote. Then go to settings tab Find some kind of tuner settings. You will want it set to Air not Cable. Then find autoscan channels. Make sure it's set to digital channel scan. Then wait a few minutes until scan is complete.
Jun 20, 2011 | Philips Televison & Video
I need to know what steps need taken in order to update my Sony LCD Digital TV to accept the 1st phase of the Wow Cable digital channel conversion
U mean u want ur tv to getting a Free DTV AIR incomming broadcasting tv channels?Yes.U must have a good antena like a roof or a digital antena plug into the tv hole that said ANT.Go into tv menu goto SETUP go down CH. enter and pick AIR and then press enter again for scanning for Free AIR DTV incomming broadcasting tv channels.
Apr 04, 2011 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
Recent digital conversion - cannot pick up all local channels
Have you gone into your tv's setup and reprogrammed or scanned the new channel assignments?
BTW, what is your tv model?
Jul 07, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Channels are different than my old tv!
you may be able to do a manual scan ion each channel which is similar to auto scan.
Its normal for auto scan to select random channels when scanning.
May 07, 2009 | Philips 19PFL5622D/37 19 in. LCD...
I have lost my tv channels!
I have a philips freeview box (although it is not built in). I recently lost all my channels also. It took me back to the installation screen and started to look for channels, furthermore if it couldn't find any it 'bugged out' on me. The only way I got around this was by unplugging the aerial, watching the screen trying to scan the channels and when the progress bar / channel # was near the end plugging the aerial back in. For some reason this started the scanning over again but this time it found channels! Strange I know, but maybe its different for me and one of those conspiracies that they program products to fail after a few years to make you buy more. Try this and let me know if it works Thanks Matthew
Jun 18, 2006 | Philips 26PF5320 26 in. LCD Television
Philips 19PFL3403D/27 19 in. LCD TV Logo
561 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
