Question about JVC Electronics - Others
When you put the wires in for the speakers and subwoofer do they need to be cut so that the plastic is grabbed by the clip or are they the right length and the metals connect?
  • 92 Answers
They are usually the correct side that is pre-cut.
Posted on Jun 16, 2009
You want to be able to clip to the Plastic sheath otherwise they will break off easily
How do u hook up a set of 4"x 6" HD Scosche speakers in a 1993 GMC Suburban
i`ve got the the same truck,,pry up the corners of the dash grilles,carefully so not to crack them,usually the clips tend to break off,so grab some epoxy from hardware store first(gonna need it).Remove 4 7mm bolts and pull spkr out,,cut wires and strip,,,left side will have gray and tan,gray is positive,,right side will have light green and dark green,light green is positive(GM wiring is lights in the front,darks in the rear).Using connecters attach new spkr pigtails connect spkrs and re-install into dash. Using epoxy replace clips on grilles waiting for epoxy to set,,carefully replace grilles and your done. GOOD LUCK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 24, 2013 | Car Audio & Video
How do i set up my subwoofer sawm40
Sounds like you have a passive subwoofer, you run speaker wire from 'front speaker receiver out' to the subwoofer, the 'subwoofer out' to your front speakers. Seem like your sub has a crossover that grabs the bass frequencies and passes off the rest to the front speakers
If you have a 'subwoofer line out' on your reciever and a 'line in' on you subwoofer then just use that single wire, this would be for a powered sub. You know that you have a powered sub if your sub has a power cord attached to it.
Jan 23, 2012 | Sony Audio Players & Recorders
Need wiring diagram
Step 1 Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step 2 Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step 3 Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step 4 Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step 5 Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the installation
Step 1 Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step 2 Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step 3 Obtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step 4 Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
Installation Process
Step 1 Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step 2 Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
Step 3 Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
Step 4 Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step 5 Put the fuse in the fuse holder.
Step 6 Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step 7 On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step 8 In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step 9 Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step 10 Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step 11 If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step 12 Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step 13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. That's all!
Good luck.
Mar 26, 2010 | Car Audio & Video
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Replace speakers in dashboard in a 2001 neon
Take the plastic pillar covers off of both sides of the car, remove the screws near the air vent outlets on each side, use a panel removal tool to unclip at each side and front of the upper dash panel and pull rearward from the front of the upper panel until the clips are cleared and lift and remove the upper dash panel. Remove the speakers covers and the screws holding in the speakers, disconnect speaker wires. replace with new speakers and then put everything back in the same order after testing the new speakers.
Sep 11, 2009 | Audiovox Car Audio & Video
Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Mar 16, 2009 | Bose Acoustimass 3 IV System
After market 6 x 8 speaker problems
it sounds to me you have a short in the wiring or an internal short with-in the speaker itself
Jan 31, 2009 | Dayton Audio Dayton SWC-1CO 1.0 ft³...
Change the speakers
there should be screws in the front door panels hiding under plastic clips at the door handle levers and the grab handel possibly under the window switch pack and along the bottom of the door then you just get a flat putty knife and pop the panels off there are a dozen or so push in plastic clips attached to the back of the door panels, as for the back deck lid you will go in the trunk and remove the ten mm bolts for the third brake light and remove that and look for any other ten mms sticking down and remove them. the rest will be clips that just pop up , make sure you have the proper wire harness adaptors for you stock speaker wireing so you dont have to cut them off to attach your new speakers -jeff
Aug 08, 2008 | 2001 Honda Civic
Punch p1 10" not working
I had the same issue with 2 Punch p1's. The wire stripping was most likely cut where the wires are saddled against 2 bare metal "C" shaped tabs before going toward the cone and coil. This was causing the wire to ground out. I cut both wires and **** connected them and bypassed the factory bracket. They work fine now. This is a poor desogn from Rockford and I can see where it might happen numerous times.
May 20, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Removing speaker from door in 2003 Dodge Durango
The panel is held down by screws and plastic clips. Make sure the arm rest/handle doesn't have any screws in it either. The plastic clips will pop out with enough force. (This is how all of my cars doors were designed.)
Mar 21, 2008 | Car Audio & Video
Electronics - Others Logo
49 people viewed this question
Top JVC Electronics - Others Experts
Marvin
Marvin
Are you a JVC Electronics - Other Expert? Answer questions, earn points and help others
