Question about RCA HDLP50W151 50" Rear Projection HDTV
RCA M50WH92S DLP - not turning on - no blinking
Chassis is ATC361B
Plug in & blue light on power button lights for 5 seconds & then goes off. There is a single click if you try to push it when its on or when you first plug it in. No blinking though. I removed power board - no obvious caps bulging, burn marks or breaks in the foils. Coils are continuos, the fuse is good - there is one bad looking solder where a heat sink is mounted but thats about it - not sure where to go from here - help would be appreciated. PS Lamp looks fine.
  • surferweb Jan 14, 2010
    No went into the trash. Baught a 42"Magnavox Plasma off of Graigslist for $100 - needed "repair" - turns out it was a loose cable. Bottom half of screen was black. had read about this possibility - sure enough it was a bargain. Good luck with DLP.
Did you Ever find out the issue? My Exact tvv is having same issue.
Posted on Jan 14, 2010
I have an RCA M50WH92S and when i turn it on the power light flashes 5 times and no picture. I have replaced the bulb today. any ideas?
first is parts for this set can get expensive---I would do two things first:
1. Look to see if lamp comes on at all--even for a few seconds.
2. Look with lamp removed where it faces to see if color wheel broken/shattered or missing pieces of the wheel.
If the lamp does not come on the next suspect would be the Ballast which powers the lamp---if its bad you may or may not get sound either.
Dec 09, 2012 | RCA M50WH92S Bulb
Rca 50'' dlp model # M50WH92S turns off, light blinks 3 times
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Dec 25, 2009 | RCA Televison & Video
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The power light comes on for 5 seconds then goes out and it does this 3 times then completely powers down. when i hold in the power button it blinks 1 time then a few seconds later it blinks 9 times what...
It sounds like youre talking about a RCA ITC222 chassis HDTV if so you need a flyback and CP150. Post the model number and I will post a link where you can get the parts with free instructions oh how to do the repair.
May 04, 2009 | Televison & Video
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Binks 5 times
You need to replace the capacitors on the power board. this is a very common problem with the RCA dlps See my tip under my profile for the ATC336 chassis RCA, your model is the ATC311 but it applies to your model as well.
Aug 05, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA DLP SCENIUM HD50LPW166 NO PICTURE OR SOUND
let me know the model number of your set and I should be able to help you out with it, as the ATC dlp chassis have different things that goes wrong but I should be able to help you out as RCA DLPs are my favorite to diagnose.
May 21, 2008 | Televison & Video
RCA HD50LPW175 50 in. HDTV Television
Yes I should be able to help you figure it out. First look on the rear of the set to check what the chassis number is. Should be an ATC 336 but it might be a ATC323 let me know the chassis number and we can go from there on diagnosing the problem
Feb 15, 2008 | Televison & Video
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
683 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
