Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My water turns green when we shock it I have drained twice now Please help!!!
  • 93 Answers
Start with testing your chlorine and ph add liquid shock and conditioner to water dont use algecide you have to get clorine to open up this is critical ph clorine and conditioner you should get a good clorine reading or you have to add more shock
Posted on Jun 16, 2009
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
Getting same green film on top of water that is the same color green as the copper piece in the salt water pump has turned
The two green colors may be associated somehow but when you say anything about green water I think it is more likely the water is turning green from algae. The best way to rule this out is to test the chlorine level and then shock with vinyl shock to about 10 ppm. If it is algae then the it may be cloudy but should turn more blue rather than green. If other chemistry is good such as salt concentration and stabilizer then running the pump, filter and chlorinator according to the Intex manual. When a pool is shocked the filter can get dirty quickly and then reduce the flow. For this reason make sure you clean the filter. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
I have an 18 by 48 Intex easy set pool and have had a high salt reading I emptyed about a 1/3 and ran clean in but still to high now its turning green what do you suggest I shock it with?
For your pool size you should have started with 160 lbs of salt. 18x48= 6,400 gallons of water. The manual says the only way to lower salt is to partially drain and refill with water, I do not believe there is anything you can add to remove salt. I would think you can throw in some regular chlorine shock to get the green out while you are adjusting the salt level.
Jul 11, 2011 | Intex Automatic Salt Water System for ...
5 days ago the water in my pool went green. I have tried everything, I have adjusted the ph level and clorine, I have added copper sulphate, and anti algae. I have also tried a shock treatment, and have...
you may have an underlying problem like phosphates or damage filter cartridges. Have the water tested for phosphates and inspect the filter cartridge(s) for any damage around the ends where it makes the seal to the filter body. Stay away from copper sulfate as this can lead to staining. Try using a polyquat60 type of algaecide or a colloidal silver type. Algae particles are microscopic, if the water turned green and not just the walls, chances are you may have to drain it and start again. There are some products like fiberclear that can increase the filter efficiency temporarily to help clear it up. You should be able to find it at your local pool supply store.
Aug 24, 2010 | Intex Pool & Spa
Shocking
test water to see if you have a free chlorine reading check ph we use 8 gallons of liquid shock with a water conditioner make sure you have vaccumed first to remove algea dont vac through pump put hose over top of pool start water flow with a wet vac at end of vac hose just turn on vac to start water flowing
Jun 16, 2009 | Intex Automatic Salt Water System for ...
My salt is high, does this cause pool water to turn green? why is my pool water green?
t is too high, the generator shuts off so no chlorine is being created; hence the green pool. Drain water and add fresh until the salt level is diluted back to the range your generator manufacturer suggests and your chlorine will return. In the mean time, shock the pool to get rid of the algae and the generator should be able to maintain it from there.
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
298 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
