Washing machine will not drain or spin out.
My Roper washing machine is about 7 years old. Three days ago it stopped draining and spinning out. It will wash on all cycle but will not drain or spin out on any cycle.
    President:
  • 3,113 Answers
Model number please.
Posted on Jun 16, 2009
How to get Roper Washer to drain & spin? My Roper washing machine is only a few months old and now it won't spin out or drain water at any level. I even tried just rinse & drain. Model #...
since it is only a few months old, it must be under warranty. So try that first before touching any repair job lest you void the warranty.
Jul 30, 2014 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | Roper Washing Machines
Roper won't drain
doe's it go into the spin cyc if not spin the lid switch is broken
Aug 19, 2009 | Roper RAS6233KQ Top Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Washer will not spin or drain water
I have a roper washing machine model RAB 2121kw and about a year ago it did the same. I was at the machine when it tried to spin one day and i opened the lid and spun the drum by hand a few times then shut the lid and slowly the drum started spinning. One problem is that i have just moved the washer and i now have an oil leak. When the drum wouldn't spin i think the motor heated the oil seal on the gear case and now it leaks. I have looked into it and don't think its that hard of a thing to change.
May 24, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
