Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet washer WFW9500TW. I'm getting SUD followed a short time later by F35. Every time. Every load type. Use 'He' detergents. Always run the cleaning cycle with bleach whenever the indicator light comes on. Help!
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Posted on Sep 28, 2010
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Whirlpool Duet Washer, washer starts and then stops code F35
    Hello & Welcome to FixYa
    F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
    Kevin
    Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    My washer frecuently shows sud and F35 can you help me solve this problem
    The sud signal...You need to use High Efficiency detergent....or the amount your using is to much.
    Nov 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet -Sud displays and washer stops
    I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
    http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
    I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
    Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Start a load in my 9150 (barely one year old), and either goes to F35 or to SUD, then F35. Have to shut breaker off to get it to stop! This happens 90% of the time! Serviceman came out and said I needed...
    this washer has a provision to keep rinsing until the oversudsing condition is cleared [SUD] - this is caused by using too much detergent or the wrong kind of detergent - use only HE rated detergent, it is formulated to clean with a minimum of sudsing - why are the clothes tangled? you're overloading
    Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F35 flashing
    if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
    Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    SUD and F35 codes come up at beginning of cycle
    open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
    clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
    Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F35 Sud errors
    OK, you can't use regular Gain detergent in this washer. you will need to use the recommended (HE-High Efficiency) brand. its the only way to avoid the SUDS.
    Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    951 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
