Question about Frigidaire FGF337EC Stainless Steel Gas Kitchen Range
Can you give me easy install directions?
My mother-in-law gave us her oven-stove combo because she wanted a new one.  We'd like to install it ourselves. Can you help?
  • 27 Answers
Are yours and hers both freestanding? (do they both have a drawer at the bottom?) if so measure the width to see if hers will fit. if so, turn off the circuit breaker to your stove. remove the drawer of your stove. do you see the plug? unplug it. now just slide it out toward you being careful not to damage the floor. installation opposite of removal.
Hope this helps
Posted on Nov 01, 2007
My stove will bake but will not broil. I figured it needs a new broiler element but can't find the part. would it be listed under another name and is it easy to install. I should also get a new glow bar...
first off you need the model number to get the right parts,if it's a stove with the burners on top open the bottom draw and get the model number off the frame,call your parts store and tell them if it's gas you need a broil ignitor if it's electric you need a broil element,and yes it's easy to do,make sure you unplug it or go to the fuse box to shut down the power first.if you sent the model number i could give you the part number and tell you what to do
Dec 21, 2010 | GE Ovens
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have just got a new stoves cooker and i need the manual for it, the model number has worn away a bit but from what i can see this is the model number 039850512
If you contact STOVES with that number, they should be able to help you. If you want a copy of my 720EF manual, supply an email address and you can gave a copy.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
Replacing oven burner element, the lower element, for a GE stove
(I think it is 50 watts or volts??)
Most electric ranges are supplied with 220 volts - this is, especially at 60 Hz, deadly. You were lucky this time.
If the wires are not welded onto the element contacts, they might be so-called 'quick-disconnects' that pull straight off of blades that are part of the elelment.
You probably haven't hurt the range with the momentary short circuit since the chassis of the range is connected to neutral or ground so you just gave your breaker a workout. BTW, I have had to replace late breakers after they tripped. They wouldn't stay reset any more even after the problem was removed from the circuit. Don't be surprised if yours doesn't stay reset; it may not be a fault causing it.
Jan 18, 2009 | General Electric Stove/Oven/Range Chrome...
Need model number & manual
According to the UPC code, this is Remanufactured Akai LCT2701TD 27 Inch LCD TV/DVD Player Combo
Nov 18, 2008 | Akai LCT3701AD 37 in. LCD Television
DVD'S will not play..
Sounds like the unit is bad, or set to the wrong Regional Code. Its not easy to set the regional code and it varies by model. You are better off buying a new DVD player given they can be found for under $30.
Aug 28, 2008 | Samsung DynaFlat CXM2785TP 27 in....
Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty.
Sep 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire FGF337EC Stainless Steel Gas Kitchen Range Logo
191 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
