Question about HP 32sII Calculator
The right hand column of buttons (+,-, etc) doesn't work at all!
I carefully opened my HP 32S but this has not be useful for fixing it: there isn't serviceable parts inside, only a big IC and a lo of thin wires that start from IC's leads.
I could have opened the keyboard assembly too, but I think that the problem is more serious and it depends from the CPU.
  • app_3rp12813
    app_3rp12813 Mar 12, 2012
    Please see HP archive post:http://www.hpmuseum.org/cgi-sys/cgiwrap/... Or search for: "hp 32s repair - dead right column of keys". This solution works if pinching the case on the right side below the screen fixes the issue.
    Before trying this fix though, I successfully fixed my 32S by putting crazy glue (Loctite 495) on the crack on the right side just below the screen near the 1/x key - and of course pinching it together until the glue dried.
  • 72 Answers
SOURCE: HP Pavilion zv5000: Screen blan, power light, fans are on.
lala linda is right. . . repairing the power pin isn't that expensive ... In fact I've fixed some myself and it's really not that hard. It is time consuming and tedious to make sure that all the bits and pieces fo back in the right place. Take some pix as you take it apart and you will find that's it much easier when you go to re-assemble the unit. btw . . . The power pins are available on the net for $ 10 or less usually.
Also . . .Once you get it fixed get a Cable retention device to make sure you don't damage the pin a second time. Personally I recommend (and use) this one.
Posted on Sep 24, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Thin Red Line on Left Side of HP Pavilion DV2000 Lap Top Screen
Majority of time it's the lcd that has a problem which creates the red line, otherwise it's the GPU (video processor).
Try hooking up your computer to an external monitor. If you see the line on the external chances are it's the lcd.
This method of testing isn't fool proof but either way the problem is hardware related.
Let me know if you have any other questions.
Posted on Mar 04, 2009
SOURCE: side key functions on HP#5189 keyboard
Left side keys - moon-hibernating mode, club+hp - takes you to hp internet club (lots of resources,free classes, etc on hp), globe spinning-takes you to internet-yourhomepage, envelope-takes you to windows email, magnifying glass- takes you to windows live search, ?-takes you to help
right side keys- arrowup1-opens disk drive, arrow up 2-opens 2nd disk drive if you have two, solid dot-opens dvd suite, arrows left-rewind, arrow right -fast forward slow, 2 arrows right-fast forward fast, and solid square -pause these are all media functions
I discovered all of this by taking a chance and pushing the key to see what happened. really wish they put a manual, or screen showing functions for the keyboard. hope this helps someone else!
Posted on May 05, 2009
lserni
  • 466 Answers
SOURCE: keyboard not working due to a spillage over keys
Very possibly, yes. Usually the internal parts of RF keyboards are heavily customized and a shop would need to keep tons of parts for every different keyboard under the sun.
Also, replacement plus spares will often cost more than a new keyboard, so there's little advantage in repairing.
Depending on the spillage, sometimes you can repair the keyboard. RF keyboards are much more difficult to fix because the spillage may have shorted circuits or oxidised contacts and tracks.
But if you've nothing to lose, and especially if some keys are working (indicating that the transmitter electronics, the most delicate part, is still alive), then you can take apart the keyboard (screws underneath, and retainer clips too). Under the shell there are other screws holding the typing surface. Removing them, the back of the surface comes off, revealing a contact membrane and a wealth of printed curlicues.
Wipe the curlicues with a lint-free cloth and alcohol to remove coffee and sugary liquids. Inspect carefully for oxidation and rust; sometimes you can remove it with a pencil rubber. Spray with a contact enhancer spray such as DeoxIT.
The membrane is the tricky part: usually lukewarm water or alcohol will do, but it depends on the formulation of the contact pads (usually black round thingies). Sometimes you can see which pads have been affected by the spillage and clean them with a cotton swab.
With RF keyboards priced around US$ 30, frankly I'd do that only for the fun of it.
Posted on Oct 29, 2009
  • 284 Answers
SOURCE: Thinking of buying a used HP 2840 but just heard bad news . .
HP LaserJet 2840 is an old machine. I would like to propose Canon imageCLASS MF8050 to suit your requirement.
Posted on May 26, 2010
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
Need a user manual for whirlpool doubleoven
Here is a link to the Whirlpool Support site for that model of oven:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/GB
Just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open up a new browser page for you automatically.
Then just type in the model number ( AKZ160WH ) into the COMMERCIAL CODE text box that you see there and then click on the SEARCH button right beside it.
When you see the links to the manual come up immediately below that, look under the column titled IFU COMPLETE on the right hand side.
Now click on the OPEN button under that column and another browser window will open automatically and will allow you to see the contents of the user's manual for your oven.
Please comment back to this page if you have any trouble and I will walk you through the process step by step.
Good luck and take care.
Joe.
Oct 31, 2011 | Ovens
I deleted my disc drive by accident now cant play or burn cds
Check device manager in control panel, see if the DVD drive is shown there. If not try this:
Close all open programs
Click on Start
Click Run
Type REGEDIT and press Enter
note: Vista doesn't come with the run command enabled so just type REGEDIT in the search bar above Start..
Click on the plus signs (+) next to the following folders to open them.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
(looks like same file name for XP and Vista?)
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
If you see any of the above keys, right-click on each of them and choose Delete
Close the Registry Editor
Reboot your computer
Click Start
Jul 18, 2011 | Computers & Internet
The 4 black buttons in a column at the top left hand corner of the vci-100. The second one down from the top isn't sending data, and the button is kind of squiggly. I know this may just be normal wear...
The solution is likely replacement of the button switch portion. Be careful of applying too much pressure... often they have plastic hinges for the buttons and they can be broken by applying too much pressure in an attempt to get them to work.
Jun 22, 2011 | Vestax Vci 100 Midi Controller
There is a narrow green line running from top to bottom of the right hand of my sharp squid tv
You have a bad connection between the column driver and that particular column on the panel. To fix it, you would have to disassemble most of the set so you can massage the panel connector strip at that point to get the connection back. This requires a careful touch; it's possible to disrupt adjacent good connections while you're doing it. If massaging doesn't work, it's possible that the column driver chip has failed or has a bad connection to the circuit board.
In the worst case, the column inside the panel is broken. This is not repairable. Check your set's warranty to see how long the panel is covered.
May 05, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
Fix the hands correct with the dejital
1. Activate Crystal
Nov 16, 2008 | Tissot T-Touch T33759851
Non functional keys
HP 48SX and HP 48GX calculators have a membrane which connects between the internal circuit boards. This is a common failure point. The "ON" button is often the first button to go out. The calculator can be opened up can cleaned, but it is a little involved. Forutnately someone has posted pictures and information on what to do.
http://www.hpcalc.org/hp48/docs/opening/hprepair.zip
There is a text file with information. The file is big because of the pictures. Summary: Open the case, bend metal clips holding the circuit boards together. Clean up any dust and the contacts. Reassemble.
Sep 21, 2007 | HP 48gx Calculator
HP 32sII Calculator Logo
124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
