Question about Panasonic SDR-H40 HDD Camcorder
Service Pack problem
I also encouter the same problem using SP3. while installing the VideoCam suite O recieve a message that the application does not support my Service Pack ?
******************************************************************* VideoCam Suite 2.0 *******************************************************************
[Table of contents] 1. Notes about operating environment 2. Notes about operation
<><><> 1. Notes about operating environment <><><>
1. [Important] Adobe Acrobat(R) Reader 5.0 or later or Adobe(R) Reader(R) 7.0 or later is required to read the operation manual or the help information on your PC. Get the license for using the operation manual before reading it.
2. AC adapters are recommended when using a notebook PC or a HDD/SD video camera with the VideoCam Suite. If a battery pack is used to power the HDD/SD video camera or the notebook while recording or previewing motion pictures or still pictures, they may not be recorded, previewed, or copied to the PC Hard drive properly.
3. Standard configurations must be used for the fonts and screen settings for Windows(R). Depending on the settings, characters may not display properly.
4. It is impossible to use VideoCam Suite simultaneously with other motion picture editing software or video capture products. Note that this software may not function properly if software with a timer recording feature in the background is running.
5. This software will function properly only when the system time is set to a value within the following range. From 0:00 on January 1, 1970, to 23:59 on December 31, 2037 If the system time is set to a value outside the range listed above, the software may not start or function properly.
<><><> 2. Notes about operation <><><>
1. After installing/uninstalling the application, a dialog box is displayed notifying the user that the system needs to be restarted. Make sure to restart the system to complete the installation/uninstallation.
2. This software can handle only motion pictures and still pictures recorded by this software or the Panasonic video camera packed together with this software. This software cannot process motion pictures and still pictures recorded by any other video cameras, DVD recorders, software, commercial DVD video, or commercial BD video.
3. User privileges for this software - It can be used by only a user with administrative privileges for Windows(R) XP and Windows(R) 2000. - It cannot be used by the Guest users in Windows Vista(R)
4. While recording, if motion pictures cannot be recorded properly for any reason, follow the procedures described in the operation manual to restart the Windows system. Motion pictures may not be recorded properly if any other application software is used while recording the motion pictures. Close all other application software and any resident programs, such as virus scanning software. We recommend closing all other applications and resident programs, such as virus scanning programs, before starting this software. While recording motion pictures on a DVD disc/SD card do not execute the following operation since it may disturb proper recording and destroy the DVD disc/SD card. - Turn off or restart the PC or DVD/SD - Switch users or log-off - Change the screen settings - Use the power saving functions, such as the screen saver, sleep, standby, and pause. - Close this application by force
5. To record motion pictures on a DVD disc or an SD card, check that the motion pictures can be recorded properly. After checking that motion pictures are recorded properly, delete the original motion pictures from the PC Hard drive.
6. When the edited motion picture is output in MPEG-2 format, some scenes may not be generated completely in MPEG-2, and some parts of frames may be shifted or omitted.
7. When motion pictures are copied from a DVD-VR formatted DVD disc to the PC Hard drive, data other than motion pictures cannot be copied.
8. Do not modify or delete any files or folders related to this software. Otherwise, the software may not function properly.
9. This software can only process DVD-Video discs recorded by this software. This software cannot properly process DVD-Video discs recorded by any other DVD authoring software.
10. This software cannot process motion pictures or DVD discs/SD cards that are copyright protected.
- Microsoft(R) and Windows(R) are registered trademarks of Microsoft Corporation in the United States and other countries. - All names, company names, and product names used in this document are the trademarks or the registered trademarks of their respective companies.
Posted on Jul 05, 2009
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
Panasonic SDR-H80, Need service pack for video cam
I hope you have WIN XP on your computer. Windows XP has 3 versions of service pack (SP) available. SP1, SP2 and SP3. For more information on obtaining SP, please refer:
http://support.microsoft.com/kb/322389
Following is the direct link for downloading SP3
http://www.microsoft.com/downloads/details.aspx?FamilyId=68C48DAD-BC34-40BE-8D85-6BB4F56F5110&displaylang=en
NB: SP is a huge file and will take long time depending on the speed of your internet connection. SP2 download would fail in 'dial up' internet connection. Also installation of SP will take a long time, depending on the configuration and the performance of your system
Dec 16, 2009 | Panasonic SDR-H40 HDD Camcorder
I have SDR-H60, installed the videocam suite on my PC but cant us
The software will work only if you attach the camera to the electricity cable comes with the camer...The software will not work using the battery.
Apr 28, 2009 | Panasonic SDR-H40 HDD Camcorder
Trying to install videocam suite 1.0 on xp home edition
Try right clicking on the installation .exe and clicking Properties. There might be a tab that says Compatibility. Click that and choose XP or XP/SP2 from the list and press apply.
try running the install now..
Hope this helps
Season's Greetings!
chris (ziraffa)
PS Here's the updater file for Videocam Suite too, which will be handy if you do manage to get it installed...
http://panasonic.jp/support/global/cs/soft/download/videocamstuite_v10.html
Dec 19, 2008 | Panasonic PV-GS500 Camcorder
VideoCam suite incompatible with Vista SP1
Tried to install VideoCam Suite 2.0 and my computer with Vista says: "This application does not support this service pack."
Sep 04, 2008 | Panasonic PV-GS500 Camcorder
VideoCam suite 1.0
Just install the Software suite, disregard the message. it may be because the when the suite was released the current SP released was SP1 or 2, when you connect the camcorder make sure that the camcorder settings are set to PC connect (or whatever setting for a PC connection), make sure that the ac adapter is connected.
Hope it helps
Aug 09, 2008 | Panasonic PV-GS500 Camcorder
Panasonic Palmcorder Camcorder sdr-h40p/pc Software
For the VideoCam Suite 1.0 (software) that comes with the camcorder requires Microsoft Windows xp professional service pack 2 but I have service pack 3. How do I transfer from the videocam to my PC?
Jun 13, 2008 | Video Cameras
Audio problem
is that an Microsoft Official Service Pack? anyways. Try using a System Restore and choose a restore point on your problem.
Sep 13, 2007 | HP Creative Sound Blaster Audigy 5.1
Panasonic SDR-H40  HDD Camcorder Logo
536 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
