go to www.comcast.net and click on the Help link, you should be able to find the remote codes and instructions on how to program it...also do a google search for COMCAST REMOTE CODES.
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
There is a code out there to try. The code would be 47. Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
