Question about Infinity Intermezzo 3.5C Center Speaker
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
I have my infinity 3.5c centre speaker.  There are 2 5.25" woofer supposted to powered by 250V outlet.  that 2 5.25" woofer suddenly have no sounds.  I checked power cord and the AC fuse and still can't give out any sound, but the power light in on.   Any suggestion for this situation? thank you.
  • RSNodell Mar 31, 2008
    No sound from 5.25" woofers. Checked fuse and power cord. Thanks
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Posted on Apr 10, 2008
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
on Jul 08, 2014 | Sony 182556522 1-825-565-22 SUB WOOFER...
No power getting to infinity interlude il100s
you have a nasty short cercuit in your woofer box due to constant mooving around or pulling the cords so get it fixed befor it costs you a lot more muney
Jan 12, 2014 | Infinity Audio Players & Recorders
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
No sound out of 15 speaker and only about half the sound out of horn
1. Confirm the woofer is not blown. Remove it and test it by using an AA battery and wire from the battery to the woofer terminals. When connected, the cone should jump. Alternately, if you have a meter, you can measure impedance. Infinity (or no jump with the battery method) means the coil is open and the speaker needs to be reconed.
2. If the woofer tests good, inspect the connections and wires from the input. Ensure there are no breaks. If the crossover includes a PC board, check for cracks or solder breaks and blown fuses / thermal damage. Repair as necessary.
If the woofer tests good and the wiring and connections are sound, reinstall and test. If there is still no sound from the woofer, test it by conecting it directly to the amp. If there is audio coming through the woofer, the issue lies within the cabinet. Consider replacing all internal cabinet componentry, including inputs. If the input is a 1/4" jack, it is likely thae contacts are bent out, away from the connector. Bend them back to center slightly, and clean them with alcohol or "deoxit".
"Half" the sound from the horn seems normal, as it is not intended to produce bass. If you mean half-volume, that is dependent on settings and measurements and is difficult to diagnose. clmrt5000_1.jpg
Jan 07, 2011 | Yamaha S115-IV 15" PA Speaker Cabinet...
My creative speakers woofer is damege plz repair woofer.
sir I am using 2.1 creative inspire speakers system, at present no sound is coming in the speakers or woofer, what is the problem.
power is on and after connecting the speakers to woofer from pc no sound is coming. what is the problem. please help me. thanks rajanna
Jun 01, 2010 | Creative Labs Inspire 6600 Computer...
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
design u r aucostics properly
Jan 10, 2009 | Infinity BU-80 Speaker
Infinity Intermezzo 3.5C Center Speaker Logo
223 people viewed this question
Top Infinity Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
