Question about Aiwa CDC-X217R CD Player
Aiwa cdc x217yu free wiring diagram
No back plug need the diagram of the prongs;8 top,8 bottom please
informatica
  • 1114 Answers
SOURCE: Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Posted on Aug 06, 2007
thesoundman
  • 41 Answers
SOURCE: Help
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
imseth85
  • 30 Answers
SOURCE: aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Posted on Mar 31, 2008
SOURCE: Aiwa CDC-X207
hi yellow go in left bottom corner
Posted on Aug 17, 2008
SOURCE: Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Posted on Feb 15, 2009
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Just had aiwa cdc x204 stolen from car but they left wiring harness intack. Cannot find this stereo anywhere. Is there another Aiwa or make that uses same wiring harness?
Most modern car stereos all use a standard plug (the name escapes me at present) so virtually any stereo should just plug in...
If your not sure, pop in to a motor parts place such as halfords and ask them to take a quick look at the wiring in your car... they will tell you weather it is standard or not...
Aug 27, 2010 | Aiwa CDC-X204 CD Player
I need a wire harness for a cdc x217yu
i found you a harness for your deck, it's 5.99 and it's on ebay and it's new, just go to ebay and type in awia wire harness
Feb 09, 2010 | Car Audio & Video
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
Aiwa CDC-X504MP wiring diagram
  • Yellow-Constant power
    Black-Ground
    Red- Power
    Blue-Antenna
    White-Left Front +
    White/Black-Left Front -
    Grey- Right front +
    Grey/Black- Right front -
    Green- Left Rear +
    Green/Black- Left rear -
    Purple- Right Rear +
    Purple/Black- Right Rear -
    Blue/Black- ?????
Feb 26, 2009 | Car Audio & Video
Aiwa CDC-X207
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa CDC-X517M Car CD Receiver . . .
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Dave
Jun 20, 2008 | Aiwa CDC-X517M CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Help
Jul 07, 2007 | Aiwa CDC-X217R CD Player
AIWA CDC-x227 CDPlayer
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Dec 03, 2006 | Aiwa CDC-X227 CD Player
Aiwa CDC-X217R CD Player Logo
671 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
