Question about Garden
Mower started fine and ran good for 5 min. before white/blue smoke started comming from exhaust. Blade disengaged and smoke left. After a couple minutes of regular engine running heavy smoke returned.
    Problem Solver:
  • 5 Answers
First make sure you're not leaving your gas lever on 'choke' after starting your mower....especially if its a fairly new mower.
If its an older mower you may have a valve thats sticking and allowing too strong of a gas mixture.
If its the latter and you fancy yourself a handyman and want to tear into it...check on-line. Their are a number of web-sites that may be able to help you with your problem...such as this one:
http://home.howstuffworks.com/home-improvement/repair/how-to-repair-small-engines.htm
Hope that helps you.
Posted on Jun 17, 2009
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Why does oil leak from the exhaust when I crank my mower an blue/white smoke appear?
If you are saying it smokes for a short period after starting.most likely you have worn valve stem seaps " O " rings worn will allow a small amount of oil left in the overhead valves to leak past the seals and into the cylinder when shut down..try some good engine restore and add to your oil..if the smoke is constant...your engine will need an overhaul..good luck
Mar 17, 2015 | Garden
Burning oil
Assuming its a briggs and stratton
kohlers have hydraulic valves
check its not overfull of oil
smell the oil does it smell like gas?
if so remove carb. clean thoroghly and drain and refill oil
check valve clearance .004 both exhaust and intake (cold engine)
valve cover gasket could be leaking on the exhaust
could have a partially blown or blown head gasket also
Jun 13, 2013 | Cub Cadet Garden
When I engage the blades, I smell and see blue smoke, so disengaged the blade
Its not the drive belt. You have a bearing or etc. out.
I just have problem. The spindle bearing was bad.
Oct 01, 2012 | John Deere 22HP VTwin 48" Riding Mower
Engine is blowing whit , then blue smoke from the exhaust , then the motor shut's off ???
I have had this happen on my Murray riding mower (Briggs engine. The problem turned out to be a stickling float/needle valve in the carb flooding the engine. . Tap the carb with a small hammer and it usually frees up, but it will probably return. I also found that with the engine off, that fuel would overflow the cab, into the engine and into the crankcase. I had to put in a shutoff valve in the fuel line.I rebuilt the carb, but the problem returned after a while. low quality carb.
Dec 04, 2017 | Garden
I have a briggs and stratton quicksilver, just got some string stuck round blade and mower stopped turned it on it's side freed string started up and oily smoke coming out of exhaust
Not to worry. When you tipped the mower on its side, oil ran into the exhaust. Allow the engine to run few minutes and it will stop smoking. The B&S engine will put oil in the muffler if tipped to the left, and oil into the carburetor if tipped on the right. The only safe way to tip the engine is where the spark plug is pointed upward.
Don't forget to check your oil level and adjust as necessary.
Sep 05, 2010 | Briggs & Stratton Garden
White smoke and some oil coming out by exhaust
check your oil level in mower. probably too much.
Jul 04, 2010 | Toro Lawn Mower With Toro Power Tools
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
