Question about Saeco Caffe Charisma Espresso Machine
My Saeco Caffe Charisma leaks water from the frother as it brews.
It leaks from the frother as it brews each cup. I keep a empty cup under it but am afraid it is only going to get worse. I am mechanically inclined and will repair myself. Looking for some ideas as to where the problem lies. I figure it is probably a o-ring or some sort of seal. Any help would be appreciated.
Thnaks, Bil
  • 1,089 Answers
Hi
Mi=ore than likely you have something under the needle seat that is holding the needle open. Usually it is scale. Try doing a descale manually. Mix the solution and put it in the water tank. Turn machine on and then immediately open the water knob. Run about 8 oz. and turn machine off. Let stand for 10 to 15 minutes. Then repeat an 8 oz. run and turn off. Again let stand. Do this until the tank is gone. Then rinse, and test. If that does not do it, you will have to remove the top and remove the cover on the manifold that holds the needle and clean manually.
Posted on Jun 16, 2009
Clogged, not much coffee coming out
That is a common problem.
especially if it has not been cleaned
most likely it is the metal screen filter in the brew group
clean the brew group
Jan 15, 2014 | Saeco Caffe Charisma Espresso Machine
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
Saeco charisma will not prime. pump runs when turing steam/water knob but no water delivered out of steam tube
Try to take a bellow pump or similary and force in water in the water inlet, make sure you have the steam knob open when you do this.
Aug 06, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Cafe Charisma
no! the max temp is pre set to about 90oC to 95oC on the p.c. board. any higher temp will cause the the coffee beans/grounds to burn, thus BAD TASTING coffee , according to most experts (barrista)
Feb 08, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
194 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
