Back to:
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Toshiba Television (by 2 users)
posted by ardell on Oct 31, 2007
When the T.V. is turned on, there a thin line going horizonal across the front of the T.V., no picture will come in,  unless you are constantly  hitting the front of the telelvision and the picture pops in.  there is always sound. need someone that works on this problem in my area, I live in Bloomington,  ILL.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by SS525, posted on Jun 22, 2008
3/8 th colored horizontal band across screen after it has been operating for a few minutes. Push down on top of cabinet and pic returns momentarily. It appears to bea vertical time base problem. What components do I need to change, to coorect this on a TXG 2548? Nice set, recent problem!
RN
Solution #1
posted on Nov 01, 2007
Not Rated (0)
latino
Rank:Guru Guru
Rating: 85%, 131 votes
it could be a loose or bad solder joint
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Toshiba Television:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Disney 13" TV
I just moved recently and I don't know if something...
ESA ET427E 27" TV
need a remote control code for ESA ET427E 27"...
Sony FD Trinitron WEGA KV-32FS120 32" TV
checked strw 5753 and resistance ( r 627 ) burn can't read...
Zenith C27A24T 27" TV
I just bought DTV converter Box for my 27" Zenith...
Philips Magnavox TS3260C 32" TV
It will not go to channel 3 and does not respond to my...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
